Hi All,
We have integrated Success Factors as an authoritative sources for Employees in ID Cloud but we are unable to fetch future dated employee. For example, someone who’s effective start date is 1 week in future but HR did configure new hire a week in advance, so that require access can be granted/set up before he/she joins the organisation.
Can someone confirm if Success Factor connector in ID Cloud is capable to fetching future dated users?
@grpensa
Thanks for your help.
Greetings Jitesh,
Of course “sunrise” and “sunset” dates for the user base is a common customization in “on prem” IDM deployments.
I will need to further investigate the means of enabling in IdC…
I will report back.
Guy.
Hi jitesh_jain,
Thank you for your query. I’ve seen a similar query come into the support center and confirmed with our Engineering team that the current SAP SuccessFactors HR Application Connector does not pull in inactive or future-dated users.
To address this, you will need to use a Scripted REST connector. This method allows you to customize and extend the data retrieval process to include inactive or future-dated users as required.
If you need further assistance with the Scripted REST connector, I recommend raising a support ticket. Our support team can provide detailed guidance and help you with any specific requirements.
Thank you,
