I need to know can we integrate AM with Oracle EBS through Federation protocols or we will go through the legacy method (as password replay)… any advise?
I am not well-versed with Oracle EBS, however, I have a few questions that might help me assist you better:
- Is Oracle Access Manager integrated within your EBS solution?
- If not, would it be feasible to deploy ForgeRock Identity Gateway (IG) as an edge component to intercept all requests directed towards Oracle EBS?
Thank you for your reply, well:
Ans:) No, its a stand alone. -
Ans:) yes we can deploy IG … in this case will we go with the legacy approach to perform SSO for EBS users ?!!
As IG is an option, I’d like to highlight that it can indeed be a robust solution. It’s a recommended pattern, particularly for applications that don’t inherently support federation protocols. By strategically positioning IG as a safeguarding gateway for EBS access, you create an avenue to harness the capabilities of OAuth2/OIDC federation. In this arrangement, IG gracefully assumes the role of a Relying Party, enabling a streamlined and standards-compliant access to EBS.
