Hello,
We are using am and ds components of Forgerock 7.1.0 on Kubernetes 1.26 Oracle Cloud OKE clusters.
Although it has worked fine on OKE 1.26 for couple of weeks, all of a sudden the Job dispatched by amster import command started not reaching completion status.
After running the following commands, amster pod reaches completion status
echo “Importing dynamic configuration”
find config/dynamic-config -type f -print -exec cat {} ;
./bin/amster import config/dynamic-config --namespace $FORGEROCK_NAMESPACE
The amster init container and pause container logs look fine
However, the amster job does not seem completed
When i look at the job yaml status section, i see success counter not incremented but uncountedTerminatedPods array filled
In fact the amster import command ends with a timeout on the wait for condition command because of this
Does anyone know or have a suggestion how to troubleshoot this issue?
I have to fix amster import and get it working again.
