Hello,
I’m experiencing an awkward issue with a CrtificateValidationNode (AM 7.0.2; JAVA 11) for some reason it fails and I see this stacktrace
503092 ERROR: Exception in processing the tree
503093 org.forgerock.openam.auth.node.api.NodeProcessException: Unable to set LDAP Server configuration
503094 [CONTINUED] at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode.setLdapStoreParam(CertificateValidationNode.java:346)
503095 [CONTINUED] at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode.process(CertificateValidationNode.java:244)
503096 [CONTINUED] at org.forgerock.openam.auth.trees.engine.AuthTreeExecutor.process(AuthTreeExecutor.java:145)
503097 [CONTINUED] at org.forgerock.openam.auth.trees.engine.AuthTreeExecutor.process(AuthTreeExecutor.java:196)
503098 [CONTINUED] at org.forgerock.openam.auth.trees.engine.AuthTreeExecutor.process(AuthTreeExecutor.java:196)
503099 [CONTINUED] at org.forgerock.openam.core.rest.authn.trees.AuthTrees.processTree(AuthTrees.java:464)
503100 [CONTINUED] at org.forgerock.openam.core.rest.authn.trees.AuthTrees.evaluateTreeAndProcessResult(AuthTrees.java:280)
503101 [CONTINUED] at org.forgerock.openam.core.rest.authn.trees.AuthTrees.invokeTree(AuthTrees.java:272)
503102 [CONTINUED] at org.forgerock.openam.core.rest.authn.RestAuthenticationHandler.authenticate(RestAuthenticationHandler.java:228)
503103 [CONTINUED] at org.forgerock.openam.core.rest.authn.http.AuthenticationServiceV1.authenticate(AuthenticationServiceV1.java:157)
503104 [CONTINUED] at jdk.internal.reflect.GeneratedMethodAccessor181.invoke(Unknown Source)
503105 [CONTINUED] at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
503106 [CONTINUED] at java.base/java.lang.reflect.Method.invoke(Method.java:566)
503107 [CONTINUED] at org.forgerock.openam.http.annotations.AnnotatedMethod.invoke(AnnotatedMethod.java:81)
503108 [CONTINUED] at org.forgerock.openam.http.annotations.Endpoints$1.handle(Endpoints.java:77)
503109 [CONTINUED] at org.forgerock.http.routing.Router.handle(Router.java:100)
503110 [CONTINUED] at org.forgerock.openam.rest.DisableCachingFilter.filter(DisableCachingFilter.java:90)
503111 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503112 [CONTINUED] at org.forgerock.openam.audit.AbstractHttpAccessAuditFilter.filter(AbstractHttpAccessAuditFilter.java:88)
503113 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503114 [CONTINUED] at org.forgerock.http.routing.Router.handle(Router.java:100)
503115 [CONTINUED] at org.forgerock.openam.cors.CorsFilter.filter(CorsFilter.java:83)
503116 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503117 [CONTINUED] at org.forgerock.openam.rest.RealmContextFilter.filter(RealmContextFilter.java:85)
503118 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503119 [CONTINUED] at org.forgerock.http.routing.Router.handle(Router.java:100)
503120 [CONTINUED] at org.forgerock.http.routing.Router.handle(Router.java:100)
503121 [CONTINUED] at org.forgerock.openam.rest.RealmRoutingFactory$ChfRealmRouter.handle(RealmRoutingFactory.java:123)
503122 [CONTINUED] at org.forgerock.http.handler.Handlers$UndescribedAsDescribableHandler.handle(Handlers.java:180)
503123 [CONTINUED] at org.forgerock.openam.rest.RealmRoutingFactory$HostnameFilter.filter(RealmRoutingFactory.java:100)
503124 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503125 [CONTINUED] at org.forgerock.http.routing.Router.handle(Router.java:100)
503126 [CONTINUED] at org.forgerock.http.routing.Router.handle(Router.java:100)
503127 [CONTINUED] at org.forgerock.openam.rest.CsrfFilter.filter(CsrfFilter.java:91)
503128 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503129 [CONTINUED] at org.forgerock.http.routing.ResourceApiVersionRoutingFilter.filter(ResourceApiVersionRoutingFilter.java:59)
503130 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503131 [CONTINUED] at org.forgerock.caf.authentication.framework.AuthenticationFramework.grantAccess(AuthenticationFramework.java:188)
503132 [CONTINUED] at org.forgerock.caf.authentication.framework.AuthenticationFramework.lambda$onValidateRequestSuccess$1(AuthenticationFramework.java:
503132 181)
503133 [CONTINUED] at org.forgerock.util.promise.Promises$CompletedPromise.thenAsync(Promises.java:263)
503134 [CONTINUED] at org.forgerock.util.promise.Promises$CompletedPromise.thenAsync(Promises.java:252)
503135 [CONTINUED] at org.forgerock.caf.authentication.framework.AuthenticationFramework.validateRequest(AuthenticationFramework.java:144)
503136 [CONTINUED] at org.forgerock.caf.authentication.framework.AuthenticationFramework.processMessage(AuthenticationFramework.java:134)
503137 [CONTINUED] at org.forgerock.caf.authentication.framework.AuthenticationFilter.filter(AuthenticationFilter.java:85)
503138 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503139 [CONTINUED] at org.forgerock.openam.http.GuiceHandler.handle(GuiceHandler.java:51)
503140 [CONTINUED] at org.forgerock.openam.http.HttpRoute$6.handle(HttpRoute.java:206)
503141 [CONTINUED] at org.forgerock.http.routing.Router.handle(Router.java:100)
503142 [CONTINUED] at org.forgerock.openam.dpro.session.ProofOfPossessionTokenFilter.filter(ProofOfPossessionTokenFilter.java:88)
503143 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503144 [CONTINUED] at org.forgerock.http.swagger.OpenApiRequestFilter.filter(OpenApiRequestFilter.java:63)
503145 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503146 [CONTINUED] at org.forgerock.openam.http.ApiDescriptorFilter.filter(ApiDescriptorFilter.java:119)
503147 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503148 [CONTINUED] at org.forgerock.openam.http.ResponseContext$ResponseContextFilter.filter(ResponseContext.java:53)
503149 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503150 [CONTINUED] at org.forgerock.openam.http.OpenAMHttpApplication.lambda$static$1(OpenAMHttpApplication.java:60)
503151 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503152 [CONTINUED] at org.forgerock.openam.http.OpenAMHttpApplication.lambda$cacheHeaderFilter$3(OpenAMHttpApplication.java:88)
503153 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503154 [CONTINUED] at org.forgerock.http.filter.TransactionIdInboundFilter.filter(TransactionIdInboundFilter.java:86)
503155 [CONTINUED] at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503156 [CONTINUED] at org.forgerock.http.servlet.HttpFrameworkServlet.service(HttpFrameworkServlet.java:262)
503157 [CONTINUED] at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
503158 [CONTINUED] at org.forgerock.openam.http.OpenAMHttpFrameworkServlet.service(OpenAMHttpFrameworkServlet.java:47)
503159 [CONTINUED] at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
503160 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
503161 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503162 [CONTINUED] at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
503163 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503164 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503165 [CONTINUED] at org.forgerock.openam.services.datastore.DataStoreConsistencyFilter.lambda$doFilter$0(DataStoreConsistencyFilter.java:46)
503166 [CONTINUED] at org.forgerock.openam.service.datastore.ReentrantVolatileActionConsistencyController.safeExecute(ReentrantVolatileActionConsistency
503166 Controller.java:37)
503167 [CONTINUED] at org.forgerock.openam.services.datastore.DataStoreConsistencyFilter.doFilter(DataStoreConsistencyFilter.java:46)
503168 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503169 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503170 [CONTINUED] at org.forgerock.openam.rest.ProtocolVersionFilter.doFilter(ProtocolVersionFilter.java:66)
503171 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503172 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503173 [CONTINUED] at org.forgerock.openam.headers.SecureCookieFilter.doFilter(SecureCookieFilter.java:63)
503174 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503175 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503176 [CONTINUED] at org.forgerock.openam.headers.DisableSameSiteCookiesFilter.doFilter(DisableSameSiteCookiesFilter.java:105)
503177 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503178 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503179 [CONTINUED] at org.forgerock.openam.validation.ResponseValidationFilter.doFilter(ResponseValidationFilter.java:59)
503180 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503181 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503182 [CONTINUED] at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:80)
503183 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503184 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503185 [CONTINUED] at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:80)
503186 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503187 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503188 [CONTINUED] at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:80)
503189 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503190 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503191 [CONTINUED] at com.sun.identity.setup.AMSetupFilter.doFilter(AMSetupFilter.java:115)
503192 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503193 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503194 [CONTINUED] at org.forgerock.openam.validation.RequestEntitySizeVerificationFilter.doFilter(RequestEntitySizeVerificationFilter.java:72)
503195 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503196 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503197 [CONTINUED] at org.forgerock.openam.audit.context.AuditContextFilter.doFilter(AuditContextFilter.java:47)
503198 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503199 [CONTINUED] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503200 [CONTINUED] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)
503201 [CONTINUED] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
503202 [CONTINUED] at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
503203 [CONTINUED] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
503204 [CONTINUED] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
503205 [CONTINUED] at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)
503206 [CONTINUED] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
503207 [CONTINUED] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
503208 [CONTINUED] at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:373)
503209 [CONTINUED] at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
503210 [CONTINUED] at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
503211 [CONTINUED] at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1590)
503212 [CONTINUED] at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
503213 [CONTINUED] at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
503214 [CONTINUED] at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
503215 [CONTINUED] at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
503216 [CONTINUED] at java.base/java.lang.Thread.run(Thread.java:834)
503217 [CONTINUED]Caused by: java.lang.ClassCastException: class [C cannot be cast to class java.util.Optional ([C and java.util.Optional are in module java
503217 .base of loader 'bootstrap')
503218 [CONTINUED] at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode$Config$ByteBuddy$BRuwIu4D.userBindPassword(Unknown Source)
503219 [CONTINUED] at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode.setLdapStoreParam(CertificateValidationNode.java:333)
503220 [CONTINUED] ... 122 common frames omitted
503221 [CONTINUED]org.forgerock.openam.auth.node.api.NodeProcessException: Unable to set LDAP Server configuration
503222 at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode.setLdapStoreParam(CertificateValidationNode.java:346)
503223 at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode.process(CertificateValidationNode.java:244)
503224 at org.forgerock.openam.auth.trees.engine.AuthTreeExecutor.process(AuthTreeExecutor.java:145)
503225 at org.forgerock.openam.auth.trees.engine.AuthTreeExecutor.process(AuthTreeExecutor.java:196)
503226 at org.forgerock.openam.auth.trees.engine.AuthTreeExecutor.process(AuthTreeExecutor.java:196)
503227 at org.forgerock.openam.core.rest.authn.trees.AuthTrees.processTree(AuthTrees.java:464)
503228 at org.forgerock.openam.core.rest.authn.trees.AuthTrees.evaluateTreeAndProcessResult(AuthTrees.java:280)
503229 at org.forgerock.openam.core.rest.authn.trees.AuthTrees.invokeTree(AuthTrees.java:272)
503230 at org.forgerock.openam.core.rest.authn.RestAuthenticationHandler.authenticate(RestAuthenticationHandler.java:228)
503231 at org.forgerock.openam.core.rest.authn.http.AuthenticationServiceV1.authenticate(AuthenticationServiceV1.java:157)
503232 at jdk.internal.reflect.GeneratedMethodAccessor181.invoke(Unknown Source)
503233 at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
503234 at java.base/java.lang.reflect.Method.invoke(Method.java:566)
503235 at org.forgerock.openam.http.annotations.AnnotatedMethod.invoke(AnnotatedMethod.java:81)
503236 at org.forgerock.openam.http.annotations.Endpoints$1.handle(Endpoints.java:77)
503237 at org.forgerock.http.routing.Router.handle(Router.java:100)
503238 at org.forgerock.openam.rest.DisableCachingFilter.filter(DisableCachingFilter.java:90)
503239 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503240 at org.forgerock.openam.audit.AbstractHttpAccessAuditFilter.filter(AbstractHttpAccessAuditFilter.java:88)
503241 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503242 at org.forgerock.http.routing.Router.handle(Router.java:100)
503243 at org.forgerock.openam.cors.CorsFilter.filter(CorsFilter.java:83)
503244 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503245 at org.forgerock.openam.rest.RealmContextFilter.filter(RealmContextFilter.java:85)
503246 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503247 at org.forgerock.http.routing.Router.handle(Router.java:100)
503248 at org.forgerock.http.routing.Router.handle(Router.java:100)
503249 at org.forgerock.openam.rest.RealmRoutingFactory$ChfRealmRouter.handle(RealmRoutingFactory.java:123)
503250 at org.forgerock.http.handler.Handlers$UndescribedAsDescribableHandler.handle(Handlers.java:180)
503251 at org.forgerock.openam.rest.RealmRoutingFactory$HostnameFilter.filter(RealmRoutingFactory.java:100)
503252 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503253 at org.forgerock.http.routing.Router.handle(Router.java:100)
503254 at org.forgerock.http.routing.Router.handle(Router.java:100)
503255 at org.forgerock.openam.rest.CsrfFilter.filter(CsrfFilter.java:91)
503256 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503257 at org.forgerock.http.routing.ResourceApiVersionRoutingFilter.filter(ResourceApiVersionRoutingFilter.java:59)
503258 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503259 at org.forgerock.caf.authentication.framework.AuthenticationFramework.grantAccess(AuthenticationFramework.java:188)
503260 at org.forgerock.caf.authentication.framework.AuthenticationFramework.lambda$onValidateRequestSuccess$1(AuthenticationFramework.java:181)
503261 at org.forgerock.util.promise.Promises$CompletedPromise.thenAsync(Promises.java:263)
503262 at org.forgerock.util.promise.Promises$CompletedPromise.thenAsync(Promises.java:252)
503263 at org.forgerock.caf.authentication.framework.AuthenticationFramework.validateRequest(AuthenticationFramework.java:144)
503264 at org.forgerock.caf.authentication.framework.AuthenticationFramework.processMessage(AuthenticationFramework.java:134)
503265 at org.forgerock.caf.authentication.framework.AuthenticationFilter.filter(AuthenticationFilter.java:85)
503266 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503267 at org.forgerock.openam.http.GuiceHandler.handle(GuiceHandler.java:51)
503268 at org.forgerock.openam.http.HttpRoute$6.handle(HttpRoute.java:206)
503269 at org.forgerock.http.routing.Router.handle(Router.java:100)
503270 at org.forgerock.openam.dpro.session.ProofOfPossessionTokenFilter.filter(ProofOfPossessionTokenFilter.java:88)
503271 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503272 at org.forgerock.http.swagger.OpenApiRequestFilter.filter(OpenApiRequestFilter.java:63)
503273 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503274 at org.forgerock.openam.http.ApiDescriptorFilter.filter(ApiDescriptorFilter.java:119)
503275 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503276 at org.forgerock.openam.http.ResponseContext$ResponseContextFilter.filter(ResponseContext.java:53)
503277 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503278 at org.forgerock.openam.http.OpenAMHttpApplication.lambda$static$1(OpenAMHttpApplication.java:60)
503279 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503280 at org.forgerock.openam.http.OpenAMHttpApplication.lambda$cacheHeaderFilter$3(OpenAMHttpApplication.java:88)
503281 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503282 at org.forgerock.http.filter.TransactionIdInboundFilter.filter(TransactionIdInboundFilter.java:86)
503283 at org.forgerock.http.handler.Handlers$1.handle(Handlers.java:54)
503284 at org.forgerock.http.servlet.HttpFrameworkServlet.service(HttpFrameworkServlet.java:262)
503285 at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
503286 at org.forgerock.openam.http.OpenAMHttpFrameworkServlet.service(OpenAMHttpFrameworkServlet.java:47)
503287 at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
503288 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
503289 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503290 at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
503291 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503292 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503293 at org.forgerock.openam.services.datastore.DataStoreConsistencyFilter.lambda$doFilter$0(DataStoreConsistencyFilter.java:46)
503294 at org.forgerock.openam.service.datastore.ReentrantVolatileActionConsistencyController.safeExecute(ReentrantVolatileActionConsistencyControll
503294 er.java:37)
503295 at org.forgerock.openam.services.datastore.DataStoreConsistencyFilter.doFilter(DataStoreConsistencyFilter.java:46)
503296 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503297 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503298 at org.forgerock.openam.rest.ProtocolVersionFilter.doFilter(ProtocolVersionFilter.java:66)
503299 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503300 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503301 at org.forgerock.openam.headers.SecureCookieFilter.doFilter(SecureCookieFilter.java:63)
503302 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503303 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503304 at org.forgerock.openam.headers.DisableSameSiteCookiesFilter.doFilter(DisableSameSiteCookiesFilter.java:105)
503305 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503306 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503307 at org.forgerock.openam.validation.ResponseValidationFilter.doFilter(ResponseValidationFilter.java:59)
503308 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503309 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503310 at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:80)
503311 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503312 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503313 at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:80)
503314 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503315 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503316 at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:80)
503317 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503318 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503319 at com.sun.identity.setup.AMSetupFilter.doFilter(AMSetupFilter.java:115)
503320 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503321 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503322 at org.forgerock.openam.validation.RequestEntitySizeVerificationFilter.doFilter(RequestEntitySizeVerificationFilter.java:72)
503323 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503324 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503325 at org.forgerock.openam.audit.context.AuditContextFilter.doFilter(AuditContextFilter.java:47)
503326 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
503327 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
503328 at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)
503329 at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
503330 at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
503331 at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
503332 at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
503333 at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)
503334 at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
503335 at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
503336 at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:373)
503337 at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
503338 at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
503339 at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1590)
503340 at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
503341 at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
503342 at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
503343 at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
503344 at java.base/java.lang.Thread.run(Thread.java:834)
503345 Caused by: java.lang.ClassCastException: class [C cannot be cast to class java.util.Optional ([C and java.util.Optional are in module java.base of lo 503345 ader 'bootstrap')
503346 at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode$Config$ByteBuddy$BRuwIu4D.userBindPassword(Unknown Source)
503347 at org.forgerock.openam.auth.nodes.x509.CertificateValidationNode.setLdapStoreParam(CertificateValidationNode.java:333)
503348 ... 122 common frames omitted
My question is what I’m doing wrong?
P.S
I entered all mandatory fields and the issue happens only when use OCSP protocol is set to true.
