Hello all,
I’m trying to find a way to download all IDM logs and create reports from them (eg all logins 30, 60, 90, x days, failed logins, locked accounts, etc).
I’ve looked through the IDM docs and all I can find are basic curl commands and instructions to hit monitoring/logs endpoints.
Is there a way to download these logs? Or do I even need to download them to create reports? Any help would be greatly appreciated!
Hi @ezekielthawngcung,
Relevant information to collect logs from Identity Cloud is effectively documented at Get audit and debug logs :: ForgeRock Identity Cloud Docs. . This endpoint is intended to be used to integrate with an SIEM (such as Splunk) - from there you can then produce the desirable report.
Hi @patrickdiligent,
Thank you for your response. I have looked into that doc but I need to create a POC report generated using JS scripting for now. I am unsure if my team will be allowed to use Splunk for now.
Is there a way to make api calls to the logs via scripting in JS?
Look into frodo-lib as an example: https://github.com/rockcarver/frodo-lib/blob/f1668595c7440161bed631e4739a9b33fd2f4f97/src/ops/cloud/LogOps.ts#L552C30-L552C30
I recommend you use fetch
rather than tail
as with the latter, logs could be missed, or duplicates generated.
