Forgerock AM installation Failure- Could not write Amster keys
Unable to install Forgerock AM on windows , getting the below error
AMSetupServlet.processRequest: error java.lang.IllegalStateException: Could not write Amster keys
at org.forgerock.openam.authentication.modules.amster.AuthorizedKeyConfiguratorPlugin.createLocalAmsterKey(AuthorizedKeyConfiguratorPlugin.java:77)
at org.forgerock.openam.authentication.modules.amster.AuthorizedKeyConfiguratorPlugin.doPostConfiguration(AuthorizedKeyConfiguratorPlugin.java:57)
at com.sun.identity.setup.AMSetupServlet.handlePostPlugins(AMSetupServlet.java:1083)
at com.sun.identity.setup.AMSetupServlet.configure(AMSetupServlet.java:959)
at com.sun.identity.setup.AMSetupServlet.processRequest(AMSetupServlet.java:552)
at com.sun.identity.config.DefaultSummary.createDefaultConfig(DefaultSummary.java:124)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.click.util.ClickUtils.invokeMethod(ClickUtils.java:3317)
at org.apache.click.util.ClickUtils.invokeListener(ClickUtils.java:2088)
at org.apache.click.control.AbstractControl$1.onAction(AbstractControl.java:228)
at org.apache.click.ActionEventDispatcher.fireActionEvent(ActionEventDispatcher.java:259)
at org.apache.click.ActionEventDispatcher.fireActionEvents(ActionEventDispatcher.java:236)
at org.apache.click.ActionEventDispatcher.fireActionEvents(ActionEventDispatcher.java:180)
at org.apache.click.ClickServlet.performOnProcess(ClickServlet.java:746)
at org.apache.click.ClickServlet.processAjaxPageEvents(ClickServlet.java:1860)
at org.apache.click.ClickServlet.processPage(ClickServlet.java:559)
at org.apache.click.ClickServlet.handleRequest(ClickServlet.java:383)
at org.apache.click.ClickServlet.doGet(ClickServlet.java:276)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:656)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:765)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.forgerock.openam.headers.SecureCookieFilter.doFilter(SecureCookieFilter.java:63)
at org.forgerock.openam.headers.DisableSameSiteCookiesFilter.doFilter(DisableSameSiteCookiesFilter.java:105)
at org.forgerock.openam.validation.ResponseValidationFilter.doFilter(ResponseValidationFilter.java:59)
at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:93)
at com.sun.identity.setup.AMSetupFilter.doFilter(AMSetupFilter.java:127)
at org.forgerock.openam.validation.RequestEntitySizeVerificationFilter.doFilter(RequestEntitySizeVerificationFilter.java:64)
at org.forgerock.openam.audit.context.AuditContextFilter.doFilter(AuditContextFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:177)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:543)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:698)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:367)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:639)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:885)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1688)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.io.IOException: GROUP@: The trust relationship between the primary domain and the trusted domain failed.
at java.base/sun.nio.fs.WindowsUserPrincipals.lookup(WindowsUserPrincipals.java:148)
at java.base/sun.nio.fs.WindowsFileSystem$LookupService$1.lookupPrincipalByName(WindowsFileSystem.java:244)
at org.forgerock.openam.utils.file.FileUtils.getWindowsPath(FileUtils.java:149)
at org.forgerock.openam.utils.file.FileUtils.create(FileUtils.java:112)
at org.forgerock.openam.utils.file.FileUtils.createFileWithPermissions(FileUtils.java:91)
at org.forgerock.openam.authentication.modules.amster.AuthorizedKeyConfiguratorPlugin.writePrivateKey(AuthorizedKeyConfiguratorPlugin.java:82)
at org.forgerock.openam.authentication.modules.amster.AuthorizedKeyConfiguratorPlugin.createLocalAmsterKey(AuthorizedKeyConfiguratorPlugin.java:72)
... 68 more
Any idea how to solve this?
Java details for the installation
JAVA --version
openjdk 11 2018-09-25
OpenJDK Runtime Environment 18.9 (build 11+28)
OpenJDK 64-Bit Server VM 18.9 (build 11+28, mixed mode)
Hi sthaval
Did you find any solution to your problem?
I am also facing the same issue when trying to install on Windows.
AJ
Hi sthaval,
After reviewing the exception, I found that it is actually a Windows error message and not an error specific to AM. The error message java.io.IOException: GROUP@: The trust relationship between the primary domain and the trusted domain failed. is indicating a failure in the trust relationship between two domains in a Windows environment.
Based on investigation and consultation with our internal teams, it appears that the reported issue has only been raised a few times and is not related to AM. However, the following instructions were provided on the Microsoft Q&A forum to address the problem with multiple domains.
Can you test the instruction given in Issue with Windows Authentication in IIS on site (Multiple Domains) - Microsoft Q&A
Maybe you can get the Trusted Domain using powershell
Import-Module ActiveDirectory
Get-ADForest | select domains
and the user domain
$env:UserDomain
and see if there is trust as suggested.
I hope you find this helpful.
Thank you
I did not follow it up, as the another team suggested to install it on Linux OS, as they too experienced the same and was solved.However, I did try to install AM on another system having windows OS, forgerock installation was successful.
The below link is given by another response check it works for you
Hi Sheila,
I do not have the same system now, as we were in a hurry to start working, we had to move to Linux OS. Anyways thanks for the response, will check it out if anyone face the same issue.
Regards,
Sajid
Hi Sajid,
Thanks so much for your time and for providing us with a status update.
Cheers!
I was able to solve this issue on windows server by changing the Tomcat Service Log On users to some user and not a local service/local system.
Hi Sajeelani,
Thank you for sharing your solution for Windows with the community! Changing the Tomcat Service Log On user to a specific user account instead of a local service/local system is a valuable tip. Your contribution is greatly appreciated and will be helpful for others facing similar issues. :+1:
