Hi there,
Am using in my lab IG 6.5.4 and th AM 6.5.5 is it supported with this combination? Since am unable to proxy pass through to the backend.
Hi @yeramsh,
Yes, this is a supported combination. The following KB article contains a support matrix detailing all AM and IG-compatible supported versions.
I hope you find this helpful!
Cheers,
