I can’t seem to find anything related to the topic in the documentation.
Was anyone able to implement MFA based on TOTP and Google Authenticator App?
Hi scavallaro4,
Thank you for reaching out to the community.
There is a use case blog available within the Community that may provide some assistance for you. This document provides a step-by-step guide on how to create a user journey in Identity Cloud that prompts the user to authenticate with TOTP for second-factor authentication.
The instruction uses the ForgeRock Authenticator app, but it’s worth noting that ForgeRock also supports other third-party OATH-compliant authenticators, such as Google Authenticator.
I hope this information helps you verify the steps you’ve taken to implement MFA using Google Authenticator (TOTP).
Best regards,
Is it possible to use authentication module and chain to perform the same operations?
Especially the device registration
