Hi Experts,
Am getting below access denied error while running mvn install.Infact i got access to my userid shaye am able to login to (https://maven.forgerock.org and did setup setting.xml under .m2 folder.Am able to access all the dependencies but for some reason some of them are failing with below error msg. Pls advice. thanks
Access denied to JFrog. Error code 401
Hi Shaye,
I just want to crosscheck and confirm that your ~/.m2/settings.xml was generated per the steps in the following access instructions:
How do I access the ForgeRock protected Maven repositories
Thank you,
