Hi folks,
good day!
Anybody tried to upgrade IG 7.2 to 2024.3 recently? How did you take care of HTTP connector attributes and other performance tuning parameters as part of upgrade 2024.3. Thanks!
Hi folks,
good day!
There are just a few vert.x property changes. And I can’t see those as being problematic, for most. To which are you referring @Akhil.Gorla ?
Here are my queries regarding standalone mode IG: 1) Some of the HTTP1.1 spec disallowed characters needs to allow/tolerated using relaxedPathChars and relaxedQueryChars in tomcat Connector attributes in Webcontainer IG. As I understand, Out of the box, IG standalone mode will ONLY HTTP1.1 spec characters. Some of the our internal applications not comply with HTTP1.1 so how to allow those chars. How to deal this situation in standalone ? Is there any workaround to allow HTTP1.1 disallowed chars ?
Thanks!
Thank you for exposing your situation.
In regards to your first point: Non compliant HTTP1.1 character sets. This is discussed at vert-x3.github.io . And comes with many warnings as well.
Additionally, there is some character set encoding configuration handled by IG. Be forewarned that much of the application supports strictly UTF-8. But, for example see: Transformations :: ForgeRock Identity Gateway and
FileAttributesFilter :: ForgeRock Identity Gateway
In regards to your second point: the logging of IG is maintained in the specified logs directory. Levels of verbosity for the Route audit logs and, the Gateway and the Administrative application are completely configurable and can be configured to be exceptionally verbose.
For Auditing, please see: Audit the deployment :: ForgeRock Identity Gateway
And for the administrative and the gateway application, please see the section: Manage logs :: ForgeRock Identity Gateway
Lastly, URL rewriting is a core feature of IG (as with most http proxy applications) The rewriting can be accomplished in the configuration of your route. Can you provide an example of a problematic situation please?
From a gateway perspective, I can’t imagine what data you would be seeking that would not be found in any of these log files.
Cheers.
Guy.
Hi, Apologize for delayed response.
Here is the probelemetic application which needs below disallowed character after query parameter to process the request at IG
abc.com/api/properties?users=names|Status|Priority
After removing relaxedPathChars and relaxedQueryChars in tomcat server.xml, we see this error
java.lang.IllegalArgumentException: Invalid character found in the request target [/api/properties?users=names|Status|Priority]. The valid characters are defined in RFC 7230 and RFC 3986
Do you think URL rewriting would be correct approach for this use case or any other better solution ? Thank you
Hi @Akhil.Gorla
The issue here is that the query string parameters are using a character (|) that is not valid. The API that the request is being sent to should not use that as a delimiter, or if it is absolutely required the character should be escaped as %7C. Try changing the request to escape that character and see if that helps you.
Sure @mwtech . Will try. Thank you
Hi @Akhil.Gorla,
We’re working on enhancing the community experience. Did the posts from @mwtech and @grpensa help resolve your issue? If so, please mark the appropriate one as “Solved.” This will help other members find solutions more quickly and acknowledge the valuable input from our community members.
Many thanks & warm regards,
