ForgerRock IdP and Salesforce SAML
I am integrating FR as the idP and Salesforce as the SP when i am extracting the .crt content from the metadata file and uploading it to the SP which is Salesforce it is showing as CN=Unknown, OU=Unknown, O=Unknown, L=Unknown, ST=Unknown, C=Unknown
Expiration: 22 May 2026 13:41:37 GMT
Because of which my SAML is failing
hi @deepanshu27
Could you be more specific on your setup, are you using PingAM or P1AIC ?
Also could you share a little bit more about your config ? CoT, hosted / remote roles, etc…
Did you had a look at this page about signing and encrypting Sign and encrypt messages :: AM 7.5.0
regards,
Steph.
