Hi, AM 7, is it possible to define ttl for oauth2 access tokens based on scope sent in the token request? suppose token endpoint has a scope A in the request then the access token issued should last for say 10 mins and when it has scope B then the access token should last for 5 mins.
Hi Ed, Thank you very much. this is exactly what I was looking for. Have configured it too and it works perfectly setting different ttl for access token based on scope in the request.
I need to do exactly the same for refresh token… can’t find how to achieve that… issue refresh token of different ttl based on the scope in the request. a little help plz.
I’ve reached out to our internal engineers regarding issuing a refresh token for a different TTL based on the scope of the request. I’ll update this thread as soon as I receive the relevant information.
Apologies for the delay. I’ve been consulting with our internal teams for a solution. After further discussion, we’ve concluded that managing the refresh token similarly may require a more tailored approach.
Further analysis and testing will be essential for meeting your requirements. We suggest initiating this process by creating a support ticket using the following link: https://backstage.forgerock.com/support/tickets.
