Anyone tried to upgrade DS running as k8s statefulsets
Hi All,
I am looking for information around DS running as k8s statefulsets. I have build private docker images using samples given inside DS zip file. I was able to build DS 7.1.1 image and able to run it as CTS servers attached to my AM.
Now I am trying in-place upgrade of those containers to DS 7.2. Its failing while upgrade command is running.
Is anyone hit similar issue?
Deepak
Get the below error.
 * OpenDJ data will be upgraded from version
 7.1.1.0e6b9886a201af7b45e4081b2e36def45f87d724 to
 7.2.0.9799e558d11bc6318e3de265fbcb32b45888b240
 * See '/opt/opendj/logs/upgrade.log' for a detailed log of this operation
>>>> Preparing to upgrade
  The upgrade is ready to proceed. Do you wish to continue? (yes/no) yes
>>>> Performing upgrade
  Renaming replication changelog files from .log to .cdb suffix.......   100%
  Archiving concatenated schema.......................................   FAIL
>>>> The upgrade failed because 1 errors were encountered. Please check log for
further details
