By Darinder Shokar
Originally posted on Darinder Shokar – Medium
The new year brings exciting, game-changing capabilities to PingOne Advanced Identity Cloud (P1AIC). Among them is the powerful new feature; authentication response enrichment. In this blog, we’ll explore the challenges it addresses and showcase a live demo of how it works.
Problem Space
Customers often want to enhance the authentication experience by embedding additional context and signals into the response message for both success and failure scenarios. These enriched insights can then be consumed by UIs, backend systems and other components to elevate and optimise the user experience.
Set Success and Failure Details Nodes
To meet these requirements two new nodes have been developed; the Set Success Details and Set Failure Details nodes. Each can be dropped into the authentication Journey canvas to enrich both success and failure response scenarios.
Each node offers the flexibility to enrich the response with static data, data extracted from the session or dynamic data such as the response from an API or signals from the user-agent — or even a combination of all three!
Value Delivered
Both nodes provide lots of value but here’s a few key ones:
Experience — The ability to return API friendly contextual data in either the success or failure scenario to enhance the user experience and/or improve system performance.
Optimisation: Customers often need to make multiple calls to the authorisation server to retrieve additional context and data. Now, this information can be included directly in the response, reducing the need for extra round trips and delivering significant performance improvements. For example, session properties that previously required an additional call post-authentication can now be seamlessly provided in a single step through an enriched response.
In the failure scenario, the response can be enriched with static or dynamic data to support more meaningful error handling.
Demo
Let’s now bring things to life with a demo showcasing these new capabilities.
Deployment
Go ahead and download the journey export JSON file from here
From the P1AIC Platform Admin Console, navigate to Journeys on the left panel and hit Import
If need be take a backup
Click Browse, locate the downloaded journey export JSON file, hit Next and finally Start Import
Once complete you will have a new journey called ExtendAuthN which will look like this:
Test Script
Now the journey is deployed, lets test it and see how it behaves.
- Go ahead and grab the test script from here and modify the REALM, AM_HOST, USERNAME and PASSWORD variables to match your environment.
Default AuthN Response
Execute the script using
./success_failure_details_test_script.sh -
The initial state of the journey has been configured to not make use of the new nodes, so the default response will be returned:
Getting cookie name
CookieName is: e1a71980fe49133
Authenticating darinder user to generate SSO token
AuthN Response is:
"tokenId": "kOzk4b...*",
"successUrl": "/enduser/?realm=/alpha",
"realm": "/alpha"
Enrich AuthN Response with Static content and Session Properties
- Lets now make use of these new nodes! Open to the ExtendAuthN journey and connect the
Increment Login Countnode to theSet Success Detailsnode as below:
- Click the
Set Success Detailsnode and we’ll see the following configured:
A static value imaginatively called
staticValuewill be injected into the AuthN response with a value ofstatic_value -
Two session properties will be injected; the universalId of the user (
universalIdSessionProperty) and the Authentication Level of the user (authLevelSessionProperty)
- Execute the script again
./success_failure_details_test_script.shThis time we see the AuthN response enriched with this additional data:
Getting cookie name
AuthN Response is:
"tokenId": "uyMgn...*",
"realm": "/alpha",
New -->"universalIdSessionProperty": "id=fc53d77d-8a31-4e0f-ad55-dcaf78e002c2,ou=user,o=alpha,ou=services,ou=am-config",
New --> "authLevelSessionProperty": 10,
New --> "staticValue": "static_value"
Enrich AuthN Response with Dynamic Content
The real power of this capability is the ability to enrich the response with dynamic content. In this case we’ll demo via an API response
- Head back to the journey and connect the
Increment Login Countnode to theSet Success Config Providernode as below:
Select the Set Success Config Provider Node and open the script by clicking the pen icon next to the
ds-set-success-config-provider-script -
In the script modify
sampleAPIto match your tenant address -
./success_failure_details_test_script.shThis time we see the AuthN response enriched with all of the above plus additional dynamic data returned from the API:
Getting cookie name
AuthN Response is:
"tokenId": "Ttp5KaO7PX692CEfAd5Sdrno1Bs.*AAJTSQACMDIAAlNLABx0YjBBeU83c1l5Y2pnbG9MZjQ2MDVFVmp1NjA9AAR0eXBlAANDVFMAAlMxAAIwMQ..*",
"realm": "/alpha",
"AuthLevelSessionProperty": 10,
"staticValue": "static_value",
New --> "dynamicValueFromAPI": {
"status": "OK"
Enrich Failure AuthN Responses
The last scenario is enrichment for failure scenarios.
Increment Login Countnode to theSet Failure Detailsnode as below:
- Click the
Set Failure Detailsnode and we’ll see the following configured:
A message of Error will be injected
A details block containing an error code of 1305 with a message of
Config Provider Node Configuration Errorwill be injected
./success_failure_details_test_script.shThis time we see a HTTP 401 AuthN response enriched with error messaging a UI could use to improve the user experience:
Getting cookie name
AuthN Response is:
"code": 401,
"reason": "Unauthorized",
New --> "message": "Error",
New --> "detail": {
"Error_1305": "Config Provider Node Configuration Error"
In conclusion, one of the most requested features — static and dynamic enrichment of authentication responses is now available in P1AIC. This advancement paves the way for innovation to enhance both the customer experiences and optimise system performance.
Thanks for reading!
