Hello,
I’m evaluating the platform with apache web agent. All http request return 403 error without prompting for password authentication. Apache is setup as reverse proxy.
I followed the tutorial to setup the realm, authentication workflow, created a user … and setup the web agent. If I switch the agent off (AmAgent Off) pages are fetched properly.
Can someone give some links ?
In the log files I received the following:
OpenAM Web Agent is not configured to handle the request to /favicon.ico (unable to get agent configuration instance, configuration: /opt/forgerock/web_agents/apache24_agent/instances/agent_1/config/agent.conf, error: file
parser error), referer: http:/.../index.html
thanks
