I have been tasked with some configuration management for OpenIDM and to move any logs over to /var/log/openidm
I have seen plenty of docs discussing changing the log level and giving the location of logs but am unable to locate info for changing the logs.
I tried changing the value for java.util.logging.FileHandler.pattern in logging.properties and config.properties with a full path to the new intended destination which did not cause any change or error. I understand that the default location is based on the user.home java property. I don’t wish to change configuration or data directories at this time so I am hesitant to pursue changes to that value.
Is it possible to change the logging destination?
Any assistance or direction to helpful literature is appreciated.
