Also, If I wanted to change which columns were visible, where would I go to edit that? For example, if I wanted to remove the Full Name column and replace it with something else like State, or First Name.
Thank you for posting and welcome to the Community!
I’ve found the following information regarding changing the attributes shown by the Admin UI in Identity Cloud.
The columns shown in the Admin UI: Manage Identities → Users are based on the first four strings or boolean fields in the managed object’s order array (or as arranged in the native IDM console). Also, the “Searchable” flag on a property may be used to add or remove fields. Please note that this only works for strings and booleans.
