Does PingOne advanced Identity cloud support shared signal framework for OIDC integrations?
Does PingOne advanced Identity cloud support shared signal framework for OIDC integrations? We need to do a OIDC integration and the relying party requires shared signal framework URL which PingOne advanced identity cloud(forgerock identity cloud) doesn’t support. Is there a workaround or any other option available?
Hi @divyasharma17
Can you share a bit more detail about this use case? I’ve never heard of an OIDC integration directly requiring a SSF url. Is there possibly a miscommunication from the relying party? OpenID Foundation (the standards body behind OIDC) also runs the working group building the Shared Signals Framework. Perhaps they are just looking to integrate with you as a shared signal receiver, independent of an OIDC integration?
I find this all very interesting. “We need…shared signal integration…”
As the WG has no ratified standards as yet: “is an emerging and promising standard for sharing security signals between trusted parties”. (Dec 14, 2023; Okta)
Any implementation today is strictly a proprietary implementation. As such, the Okta/Apple Business Manager integration which has just finished the Beta, as of Mar 2024.
