Error Installing IDM 7.2
bash getting-started.sh
Executing ./startup.sh…
Using OPENIDM_HOME: /c/AM7-install/openidm
Using PROJECT_HOME: /c/AM7-install/openidm/samples/getting-started
Using OPENIDM_OPTS: -Xmx2048m -Xms2048m
Using LOGGING_CONFIG: -Djava.util.logging.config.file=/c/AM7-install/openidm/samples/getting-started/conf/logging.properties
Error: Could not find or load main class org.forgerock.openidm.launcher.Main
Caused by: java.lang.ClassNotFoundException: org.forgerock.openidm.launcher.Main
I am getting Class Not found error while starting up IDM .
Which JVM are you using? Please ensure you launch IDM on a supported JVM : Java requirements :: IDM 7.2.2
  • Patrick
Java 11
