Hello
We are doing a PoC, for a complete deployment of forgeops on AWS.
I am consulting you, because we have some requirements for the deployment.
1- Extend the identity DS schema.
2- Install Custom Authentication Nodes.
For point 1, we will do it by modifying the 99-ext.ldif {forgeops/docker/ds/idrepo/config/schema/99-ext.ldif at master · ForgeRock/forgeops · GitHub} file.
For point 2, we have NOT found it in the documentation.
Someone has done it and could tell us where to leave the jars, or if you have the link to the documentation.
Thanks.
Regards.
