Good afternoon,
We had a couple of questions about the ForgeRock Authentication module.
In the case of wanting to integrate the ForgeRock Authentication module in an app, how much could the size of this app increase due to this integration?
We also wanted to confirm that the technologies in which it can be integrated on both Android and iOS are the following:
- Android API level 23+ (Android 6 and above)
- iOS 12 and above
Thank you and best regards
Thank you for your question.
So that we are clear, server authentication modules remain at the SSO provider, AM.
If the question is how much code is required at client app to integrate the app with AM ReSTful authentication services, then the answer is there were a few ways of doing this simple client. In JavaScript, about 10 lines of code will integrate the app with the restful authentication API.
If you were referring to the client SDK, frankly it’s about the same.
Yes, your product versions are supported. Please see the release notes ofAM at backstage.forgerock.com.
