We are trying to do the frodo import export as observed in this video https://www.youtube.com/watch?v=yGPnk7gR1dY
- frodo script export -A -x
- this breaks down the script json and js files with a file based reference to the js files from within
json
“meta”: {
“origin”: “http://am.example.com:8080/openam”,
“originAmVersion”: “7.1.2”,
“exportedBy”: “amadmin”,
“exportDate”: “2023-09-27T02:54:13.201Z”,
“exportTool”: “frodo”,
“exportToolVersion”: “v1.1.0 [v18.5.0]”
“script”: {
“6b3cfd48-62d3-48ff-a96f-fe8f3a22ab30”: {
“_id”: “6b3cfd48-62d3-48ff-a96f-fe8f3a22ab30”,
“name”: “Amazon Profile Normalization”,
“description”: “Normalizes raw profile data from Amazon”,
“script”: “file://Amazon-Profile-Normalization.script.groovy”,
“default”: true,
“language”: “GROOVY”,
“context”: “SOCIAL_IDP_PROFILE_TRANSFORMATION”,
“createdBy”: “id=dsameuser,ou=user,dc=openam,dc=forgerock,dc=org”,
“creationDate”: 1433147666269,
“lastModifiedBy”: “id=dsameuser,ou=user,dc=openam,dc=forgerock,dc=org”,
“lastModifiedDate”: 1433147666269
- perform changes on the scripts as exported
- Import the script back to AM using the command: frodo script import -f script.json -n scriptname
The script imported this way shows up as garbage chars in AM scripts.
Is there a limitation on the tool with such import export?
I am on version 7.1.2 of AM which still does base64 encode the scripts inside the json files. Would that be the reason for this?
Please advice.
