This article provides steps for adding a DS 7.1.1 server to an existing DS 6.x replicated environment.
Note: We used DS 6.5.4 to create the replicated environment.
In this article, we will create two DS 7.1.1 servers, add them to the existing DS 6.5.4 environment, and show you how to test and validate the replication status at different steps throughout the procedure.
Step One:
- Setup two DS 6.5.4 DS servers.
- Configure and test replication using the following commands:
(DS1-654-4444)
setup directory-server \
--rootUserDN "cn=Directory Manager" \
--rootUserPassword password \
--monitorUserPassword password \
--hostname <FQDN> \
--ldapPort 1389 \
--enableStartTLS \
--ldapsPort 1636 \
--httpPort 8080 \
--httpsPort 8443 \
--adminConnectorPort 4444 \
--profile ds-evaluation \
--acceptLicense
dsconfig \
set-global-configuration-prop \
--hostname <FQDN> \
--port 4444 \
--bindDN "cn=Directory Manager" \
--bindPassword password \
--set server-id:1 \
--trustAll \
--no-prompt
(DS2-654-5444)
--hostname <FQDN> \
--ldapPort 2389 \
--enableStartTLS \
--ldapsPort 2636 \
--httpPort 8181 \
--httpsPort 9443 \
--adminConnectorPort 5444 \
--acceptLicense
dsconfig \
--hostname <FQDN> \
--port 5444 \
--set server-id:2 \
--trustAll \
--no-prompt
Configure Replication
dsreplication configure \--adminUID admin \
--adminPassword password \
--baseDN dc=example,dc=com \
--host1 <FQDN> \
--port1 4444 \
--bindDN1 "cn=Directory Manager" \
--bindPassword1 password \
--replicationPort1 1989 \
--host2 <FQDN> \
--port2 5444 \
--bindDN2 "cn=Directory Manager" \
--bindPassword2 password \
--replicationPort2 2989 \
--trustAll \
--no-prompt
dsreplication \
initialize \
--adminUID admin \
--hostSource <FQDN> \
--portSource 4444 \
--hostDestination <FQDN> \
--portDestination 5444 \
--trustAll \
--no-prompt
Initializing base DN dc=example,dc=com with the contents from
--hostname <FQDN>:4444:
180 entries processed (100 % complete).
Base DN initialized successfully.
Check Replication Status
$ ./dsreplication status --hostname <FQDN> --port 4444 --baseDn dc=example,dc=com --adminUid admin --adminPassword password --no-prompt --trustAllSuffix DN : Server : Entries : Replication enabled : DS ID : RS ID : RS Port (1) : Delay (ms) : Security (2)
dc=example,dc=com : <FQDN>:4444 : 180 : true : 1 : 1 : 1989 : 0 : false
dc=example,dc=com : <FQDN>:5444 : 180 : true : 2 : 2 : 2989 : 0 : false
********* testing replication between DS 6.5.4 servers ***********
$ ./ldapsearch --hostname <FQDN> --port 1389 --bindDN "cn=directory manager" --bindPassword password --baseDN "ou=people,dc=example,dc=com" uid=bjensen description
dn: uid=bjensen,ou=People,dc=example,dc=com
description: Original description
$ ./ldapsearch --hostname <FQDN> --port 2389 --bindDN "cn=directory manager" --bindPassword password --baseDN "ou=people,dc=example,dc=com" uid=bjensen description
Make an Update on an Entry
./ldapmodify --hostname <FQDN> --port 1389 --bindDN "cn=directory manager" --bindPassword password
changetype: modify
replace: description
description: New1 description
# MODIFY operation successful for DN uid=bjensen,ou=People,dc=example,dc=com
Setup Two DS 7.1.1 Servers.
NOTE: Do not use the --bootstrapReplicationServer option.
(DS3-711-6444)
setup \
--serverId 3 \
--deploymentKey AI2IkHH6nl4ZoFHCZqMiC7U6ApQfDg5CBVN1bkVDAJEkHXgWwLoFJGQ \
--deploymentKeyPassword password \
--rootUserDN uid=admin \
--hostname <FQDN> \
--adminConnectorPort 6444 \
--ldapPort 3389 \
--enableStartTls \
--ldapsPort 3636 \
--httpsPort 10443 \
--replicationPort 3989 \
--profile ds-evaluation:7.0.0 \
--acceptLicense
DS4-711-7444
setup \
--serverId 4 \
--hostname <FQDN> \
--adminConnectorPort 7444 \
--ldapPort 4389 \
--enableStartTls \
--ldapsPort 4636 \
--httpsPort 11443 \
--replicationPort 4989 \
--acceptLicense
Add the DS 7.1.1 server(DS3-711-6444) to DS1 & DS2 6.5.4 Environment
/DS3-711-6444/bin
$ ./stop-ds
Stopping Server...
$ ./dsrepl add-local-server-to-pre-7-0-topology --hostname <FQDN> --port 4444 --bindDn "cn=admin,cn=Administrators,cn=admin data" --bindPassword password --baseDn dc=example,dc=com --trustAll --no-prompt
Establishing connections ..... Done
Checking registration information ..... Done
Configuring the servers in the topology to talk to the local server ..... Done
Adding server instances keys from the existing topology into 'cn=admin data'
in the new server .....Done
Enabling 'cn=admin data' backend
Done
Creating the trust manager 'Admin Data' to be used by replication connections
in the local server .....Done
Updating replication configuration on local server ..... Done
Updating replication configuration for baseDN 'cn=admin data' on local server
.....Done
Replication has been successfully configured on the local server. Note that
for replication to work you must initialize the contents of the base DNs that
are being replicated. Run the following command(s) to do so:
dsrepl initialize --fromServer 1 --hostname <FQDN> --port 6444 --baseDn "cn=admin data" --baseDn "dc=example,dc=com" --baseDn "cn=schema"
$ ./dsrepl initialize --fromServer 1 --hostname <FQDN> --port 6444 --baseDn "cn=admin data" --baseDn "dc=example,dc=com" --baseDn "cn=schema"
Password for user 'uid=admin':
Starting initialization from '1' to '3' for base DNs: 'cn=admin data' ;
'dc=example,dc=com' ; 'cn=schema'
Starting initialization for base DN: 'cn=admin data'
15 entries processed (100 % complete).
Done
Starting initialization for base DN: 'dc=example,dc=com'
Done
Starting initialization for base DN: 'cn=schema'
1 entries processed (100 % complete).
Done
dsreplication status From DS1 6.5.4 Server Still Shows Info for the 6.5.4 Servers Without Error
$ /DS1-654-4444/bin
The displayed information might not be complete because the following errors
were encountered reading the configuration of the existing servers:
An error occurred connecting to the server. Details: Connect Error:
Connection refused
Add the DS 7.1.1 server(DS4-711-7444) to DS1 & DS2 6.5.4 Environment
/DS4-711-7444/bin
$ ./stop-ds
NOTE: Had to also stop the '--hostname <FQDN>:6444' /Users/Opendj-installs/DS7.0/DS3-711-6444 DS 7.1.1 server for this to run
Done
.....Done
dsrepl initialize --fromServer 1 --hostname <FQDN> --port 7444 --baseDn "cn=admin data" --baseDn "dc=example,dc=com" --baseDn "cn=schema"
$ ./start-ds
$ ./dsrepl initialize --fromServer 1 --hostname <FQDN> --port 7444 --baseDn "cn=admin data" --baseDn "dc=example,dc=com" --baseDn "cn=schema"
Starting initialization from '1' to '4' for base DNs: 'cn=admin data' ; 'dc=example,dc=com' ; 'cn=schema'
16 entries processed (100 % complete).
Done
Done
Done
DS1-654-4444/bin
Connection refused
An error occurred connecting to the server. Details: Invalid Credentials
$ ./dsrepl status -p 6444 -D "uid=monitor" -w password -X --baseDN dc=example,dc=com --showReplicas
Base DN / DS Status Receive Replay
delay (ms) delay (ms)
dc=example,dc=com
└─ DS/3 OK 0 0
Server / host port Error or diagnostic
1 Cannot contact server: no admin port could be discovered in its entry ds-mon-server-id=1,cn=servers,cn=topology,cn=monitor
2 Cannot contact server: no admin port could be discovered in its entry ds-mon-server-id=2,cn=servers,cn=topology,cn=monitor
$ ./dsrepl status -p 7444 -D "uid=monitor" -w password -X --baseDN dc=example,dc=com --showReplicas
dc=example,dc=com
└─ DS/4 OK 0 0
Test Replication
$ ./ldapsearch --hostname <FQDN> --port 3636 --useSsl --trustAll --bindDN uid=admin --bindPassword password --baseDN "ou=people,dc=example,dc=com" uid=bjensen description
$ ./ldapsearch --hostname <FQDN> --port 4636 --useSsl --trustAll --bindDN uid=admin --bindPassword password --baseDN "ou=people,dc=example,dc=com" uid=bjensen description
Make Modify on DS 6.5.4 Server and Confirm It Is Seen on All Four Servers
changetype: modify
description: New2 Description
Make Modify on DS 7.1.1 Server and Confirm It Is Seen on All Four Servers
./ldapmodify --hostname <FQDN> --port 4636 --useSsl --trustAll --bindDN uid=admin --bindPassword password
changetype: modify
description: New3 Description
