How to Handle Environment Specific Values During Environment Promotion for AM in ForgeOps
Hello FR community, I’m seeking some advices on how to handle environment specific parameter values during environment promotion for AM in ForgeOps.
In a ForgeOps/DevOps sense, for AM, suppose I made some configuration updates in the DEV environment(new journeys, SAML, OAuth Clients and etc.), and it’s ready to be promoted to the TEST environment. Before I can apply/promote the configuration to TEST environment (export configurations from DEV, bake new AM image for TEST, import dynamic config using Amster for TEST), I will have to replace the environment specific values. The question is how we should update it. The exported configuration have many files (both static and dynamic) and it would be tedious and error-prone to manually updated them. Eventually, it should be an automated process.
This is probably a common issue and would like to hear some advices. Thanks and appreciate it.
Best,
Le
