Hello,
I am currently working on integrating OpenAM 7.4.0 with OpenIDM 7.4.1 to ensure that all users registered in OpenIDM are available in OpenAM and can be authenticated directly through OpenAM.
My Setup:
- OpenIDM Configuration:
- OpenIDM is installed and running on
localhostat port9000. - Managed users are configured in OpenIDM.
- OpenAM Configuration:
- OpenAM is installed and accessible.
- During OpenAM setup, I tried configuring the data store to connect to OpenIDM, but it failed with a connection error.
Configuration Attempt:
OpenAM User Data Store Configuration:
- User Data Store Type: ForgeRock DS for IAM
- SSL/TLS Enabled: Unchecked
- Directory Name:
localhost - Port:
9000 - Root Suffix:
dc=openam,dc=forgerock,dc=org - Login ID:
cn=Directory Manager - Password:
[Your OpenIDM Admin Password]
Error: âCannot connect to Directory Server, the error was: Connect Errorâ
Screenshot of the Error:
Steps Taken to Troubleshoot:
- Verified OpenIDM Status:
- OpenIDM is running and accessible via the admin console and REST API.
- Checked Network Connectivity:
- From the OpenAM server, confirmed connectivity to OpenIDM on
localhost:9000usingtelnetandnc.
- Verified Credentials:
- Confirmed that the
Login IDandPasswordare correct and have the necessary permissions.
- Checked Root Suffix:
- Verified that the
Root Suffix(dc=openam,dc=forgerock,dc=org) is correctly configured in OpenIDM.
I have attached the screenshot of error.
Questions:
- Is there a specific type or configuration required in OpenAM to connect to OpenIDM as an identity store?
- During identity store configuration in OpenAM, there was no option for OpenIDM. How should I configure this?
- Detailed Steps to Configure OpenAM with OpenIDM:
- Could someone provide a step-by-step guide on how to set up OpenAM to use OpenIDM as an identity store?
- Are there specific attributes or settings in
Generic LDAPv3that need to be configured to work with OpenIDM?
- Authentication Module Configuration:
- Is there a need to set up a specific authentication module in OpenAM to authenticate users from OpenIDM?
- If yes, what are the detailed steps to configure this?
Any detailed guidance, documentation links, or examples would be greatly appreciated.
Thank you in advance for your help!
Best regards,
Anees
