How to utilize custom attributes created in IDC for AM related scripts?
Hi everyone,
We struck with scenario where we created custom attribute named “custom_familytype” in managed user object. We can utilize that attribute for IDM related operations using its “IDM property” name but when it comes to AM related operations like passing custom attribute in access token using token modification script it requires to utilize “AM attribute” name of that particular attribute and we couldn’t be able to find it.
So I need help to find corresponding am attribute name value for any custom attribute created through IDM in ForgeRock Identity Cloud.
Thanks in advance …!
fr-idm-custom-attrs
You may be able to get values for all custom attributes in a JSON format.
For reference, How to set a custom attribute in ForgeRock Identity Cloud using Scripted Decision Node?
Hi there,
what if I want to add this custom attribute “custom_familyname” in a SAML assertion? what would be the AM property for this attribute should I pass?
Thanks in advance!
If you are using journeys, you can read the value for ‘custom_familyname’ in a scripted node and set it as a session property called ‘familyName’.
Then in SAML assertion config, just map claim name to session property name. e.g. a claim called ‘family_name’ can be mapped to ‘familyName’ where ‘familyName’ is the session property.
By default, SAML attribute mapper will look for a user attribute called ‘familyName’. If it doesnt find it, it will look for a session property by the name ‘familyName’ and use that value for the claim.
You will have to whitelist ‘familyName’ as a session property for this approach.
Read the first few lines here - Use IDP attribute mapper to map user-configured attributes to SAML attributes :: ForgeRock Identity Cloud Docs
Hi Suriya,
We’re working to enhance the community experience. If you found the information helpful in addressing your inquiry, please select the Best Answer and click the checkbox below the replyimage to mark the issue as Solved.
We highly encourage our members to use this feature, as it helps those seeking assistance and those looking for previously provided solutions.
Thank you very much!
Best regards,
This sounds interesting.
Having the same problem as @Suriya Suriya I added the fr-idm-custom-attrs to the assertions and then used a customised script to return the value I need from those custom attributes in a dedicated attribute.
While this is working, the negative side effects are that all custom attributes are part of the SAML reply and that you don’t see the new attribute in the mapping of the SP as it’s in the script. So admins have to see that there was a customized script used and have to check into this.
Would be nice if the custom attributes could be addressed directly - they actually make Identity Cloud really powerful.
