IDM: How to authorize Internal role based on External role
Hello All,
I am trying to assign internal role(openidm-admin) based on the external role (Admins) in IDM.
Is there a way to tweak authentication JSON to achieve this ?
Thanks,
Bala.
Hi @bchinnaiyan
Did you try using conditional filter to automatically assign internal roles ?
Regards,
Steph.
Hi Stephen, Yes, it worked. Thanks!
