while setting up and starting IDM according to the documentation the default username and password are both: admin
However that doesn’t work
Does anyone know a solution?
https://backstage.forgerock.com/docs/idm/7.3/install-guide/chap-install.html
The default admin user is openidm-admin. It is also the password. It goes without saying that you should change that.
Thank you so much for your quick help!
Of course, the default pw has to be changed
