Installing IDM Connectors within CDK Deployment
There a preferred or suggested way to install connector jar files into a CDK setup? Just trying to do a PoC using the LDAP connector but it seems that connector isn’t included in the eval/CDK deployment.
Since the docker image has to be built it would make sense to just add connectors that are needed together with the others so that they are part of the Docker build.
Alternatively you could use the Remote Connector Service (RCS) and emulate the way that the SaaS product IDC works and have the connector with the RCS deployment, which is usually close to the source.
(I have not tested so I won’t go into any details).
