By Darinder Shokar
Originally posted on https://medium.com/@darinder.shokar
Things never stay still in the world of SaaS platforms and PingOne Advanced Identity Cloud (AIC) is no different. Next Generation scripting has been introduced, read all about it here, but the highlights are:
Stability — The introduction of a stable set of enhanced bindings to cover both common and utility operations
Ease of use — Simplified script generation via fewer imports, more intuitive return types, better debugging and an enhanced HTTP client
Reduced complexity — Ability to modularise scripts via library functions to reuse common code as
CommonJSmodules, along with seamless access toopenidmbindings
As part of Next Generation scripting, JWT (Json Web Token, overview here) generation and validation bindings were introduced. There are many use cases for JWT generation and validation, but a couple of common ones are to securely package and transport data or to create magic links to validate email addresses.
This blog walks through how to generate and validate a JWT in 4 easy steps.
So let’s get to it!
Configuration Steps
The following will configure a sample journey in PingOne AIC to demonstrate JWT generation and validation using the Next Generation scripting engine and as an added bonus demonstrate the use of library functions to log debug messages.
Note uniquely the PingOne AIC SaaS runs the same software offered to self-managed customers, which means these steps can also be followed on a PingAM 7.5 deployment. Nice!
Code repository here.
Create the library function
The first step is to create the library function. As discussed earlier, library functions promote both reuse of common code and modularisation of code. In this example, a library script is created to record SLF4J debug and error messages to log files:
From the PingOne AIC administrative platform UI, navigate to Scripts on the left panel > Auth Scripts and hit the blue New Script
Select library , set the name to
ds-node-logger-lib, the description toA logger library function, copy the contents of this file into the Javascript box and hit Save and close
Import the journey
The next step is to import a JSON file which will create the journey, with all the required nodes, linkages and associated scripts in one go:
Download the JSON export from here
From the PingOne AIC administrative platform UI, navigate to Journeys > Import > Browse > Select the file from step 1 and hit next
A prompt confirming the journey name (
DS_JWT_Testing) along with the 3 scripts that will be imported (ds-create-jwt,ds-debug-outputandds-validate-jwt) will appear. Hit Start Import -
After import, click DS_JWT_Testing. The journey should look like this:
Create a sample test user
Now we need to create a sample user to test with:
From the PingOne AIC administrative platform UI, navigate to Identities > Manage and hit the blue New Alpha realm — user
set the username and email address to
jwt@pingidentity.com. Example below:
Create a test user called jwt@pingidentity.com
Give it a whirl
The last step is to test it :)
From the PingOneAIC administrative platform UI, navigate to Journeys > click on DS_JWT_Testing and copy the Preview URL
Open an Incognito/Private browser window and paste in the URL
Enter the jwt@pingidentity.com email address and a JWT should be created, validated and then a debug screen displayed to show an attributed called
claimAttributecontaining the_idvalue of the user extracted from the JWT
Video demo:
Nice! So how does this all work then?
So at this point, you should be in a position where the journey is deployed and you can play around with it, but just to provide a bit more detail on what’s going on:
Journey — The journey first hits an Attribute Collector node to take the email address as an input. Identify Existing User then checks if the email address matches a user in the datastore; if so, the JWT logic executes; if not, a retry loop is invoked to try again in case a typo was made
JWT generation logic — The Create JWT node invokes the ds-create-jwt.js script, which first invokes a library function called ds-node-logger-lib to handle logging before generating a JWT token containing the issuer, audience, subject (_id value of the user from sharedState), plus two custom claims (uid set to _id of user and a static test_claim) all wrapped in a HS256 compliant signed JWT valid for 5 minutes. The signing key is a 256 bit key generated using openssl rand -base64 32
JWT validation login — The Validate JWT node then invokes the ds-validate-jwt.js script which pulls in the JWT token from sharedState plus issuer, audience and signingKey variables and goes on to validate the signature, extract the uid claim and insert it into the claimAttribute sharedState variable
Debugger — A debug scripted node (ds-debug-output.js) is then invoked to output state variables and shows this claimAttribute sharedState variable set to the user’s uid value extracted from the JWT
An example JWT decoded using the Ping JWT Decoder looks like this (you can get the JWT value from the debug output’snodeState.jwt field):
Example decoded JWT token
Log messages — Lets not forget that debug library script, which outputs log messages like this:
Note — The scripts output below records the secret to logs, this is for illustration/demo purposes only. Be sure to remove this for security reasons from the create and validate scripts:
"***ds-create-jwt: logger initialised",
"***ds-create-jwt: Node execution started",
"***ds-create-jwt: secret = dm9vz3sSIJDwZhQM4/YPS4iGeOqYm1qm8pNKKkhAYQc=",
"***ds-create-jwt: claims = {\"jwtType\":\"SIGNED\",\"jwsAlgorithm\":\"HS256\",\"issuer\":\"myissuer\",\"audience\":\"myaudience\",\"subject\":\"ff976117-f9bf-4cea-8f67-c6f0b6a8b333\",\"validityMinutes\":5,\"signingKey\":\"dm9vz3sSIJDwZhQM4/YPS4iGeOqYm1qm8pNKKkhAYQc=\",\"claims\":{\"uid\":\"ff976117-f9bf-4cea-8f67-c6f0b6a8b333\",\"test_claim\":\"test_value\"}}",
"***ds-create-jwt: Generated JWT = eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJteWlzc3VlciIsInN1YiI6ImZmOTc2MTE3LWY5YmYtNGNlYS04ZjY3LWM2ZjBiNmE4YjMzMyIsImF1ZCI6Im15YXVkaWVuY2UiLCJpYXQiOjE3MTkzMDU0MjUsImV4cCI6MTcxOTMwNTcyNSwianRpIjoiZTA4MDI3ZjUtODFmNC00YTU2LTgxNDUtMTJmZTA2NDJlMGZmIiwidWlkIjoiZmY5NzYxMTctZjliZi00Y2VhLThmNjctYzZmMGI2YThiMzMzIiwidGVzdF9jbGFpbSI6InRlc3RfdmFsdWUifQ.ysEdeTxZZzu2VgKuA5SmV-Cs9A65UdxUMY7qRELmHT4",
"***ds-create-jwt: Node execution completed",
"***ds-validate-jwt: logger initialised",
"***ds-validate-jwt: Node execution started",
"***ds-validate-jwt: Secret = dm9vz3sSIJDwZhQM4/YPS4iGeOqYm1qm8pNKKkhAYQc=, assertionJwt = eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJteWlzc3VlciIsInN1YiI6ImZmOTc2MTE3LWY5YmYtNGNlYS04ZjY3LWM2ZjBiNmE4YjMzMyIsImF1ZCI6Im15YXVkaWVuY2UiLCJpYXQiOjE3MTkzMDU0MjUsImV4cCI6MTcxOTMwNTcyNSwianRpIjoiZTA4MDI3ZjUtODFmNC00YTU2LTgxNDUtMTJmZTA2NDJlMGZmIiwidWlkIjoiZmY5NzYxMTctZjliZi00Y2VhLThmNjctYzZmMGI2YThiMzMzIiwidGVzdF9jbGFpbSI6InRlc3RfdmFsdWUifQ.ysEdeTxZZzu2VgKuA5SmV-Cs9A65UdxUMY7qRELmHT4",
"***ds-validate-jwt: uid = ff976117-f9bf-4cea-8f67-c6f0b6a8b333",
"***ds-validate-jwt: Node execution completed",
"***ds-debug-output: logger initialised",
"***ds-debug-output: Node execution started",
So there you have it — a quick and easy way to generate and validate JWT tokens using the shiny new Next Generation JWT bindings in 4 easy steps.
This example signs the JWT using a static symmetric key (HS256). To maintain a good security posture it’s recommended to set the signingKey variable to an Environment Secret Variable (ESV) which can then be set to a unique value per environment.
Further fun and excitement can be had by signing JWT tokens using asymmetric keys (RS256), encrypting and then signing JWTs or signing and then encrypting :)
Thanks for reading!
