Hello,
The requirement is:
Based on certain requirement condition filter (conditions can be complex to be scriptable), launch a task to perform action (disable/enable and remove groups) on a target application from ForgeRock IdentityCloud.
what is the way to achieve this? …any document how to configure this?
The requirement is:
Based on certain condition filters given if the conditions are satisfied, we need to perform either of the below actions:
- Disable application account and remove existing access for the user
- Enable application account
- Delete application account after 30 days from disabling the user/termination date
