Google docs:
Multi-Cluster Ingress
Set Up Multi-Cluster Ingress
Deploy Multi-Cluster Ingress
This article explains how to deploy the ForgeRock Identity Platform across two different clusters, and configure proximity-based routing with multi-cluster ingress.
Features:
- Fully meshed multi-cluster DS tolopology using CloudDNS for GKE
- Global HTTP(S) load balancing across multiple clusters with Multi Cluster Ingress
- Health checks to manage application level failover between clusters
- Proximity-based routing
- Active/active or failover
- Blue/green deployments
Step 1: Prerequisites
1. Cloud SDK version
- Cloud SDK version 290 or later.
2. Select Anthos pricing model
Anthos ingress controller is a Google hosted service which is used by Multi Cluster Ingress.
Choose your Anthos pricing model here:
3. Enable MCI APIs
gcloud services enable gkehub.googleapis.com
gcloud services enable anthos.googleapis.com # Enable if required based on the previous section
gcloud services enable multiclusteringress.googleapis.com
Step 2: Cluster provisioning and DS setup
- Follow the clouddns readme to set up US and EU clusters and deploy DS using Cloud DNS for GKE.
- Enable HTTP load balancing on the clusters. This can be applied either at cluster creation time or after the clusters are created.
- After following the above steps you should have the following:
- HTTP load balancing and workload identity enabled on both clusters
- Secret Agent Operator deployed
- DS deployed and communicating across both clusters
- Now you need to register your new clusters to a fleet. Multi-cluster works only on clusters that are registered to the same fleet. Ensure:
- <cluster_location> matches the location of the cluster master.
- <cluster_name> matches the exact name of the cluster.
- <project_id> matches your Google Cloud Project ID.
gcloud container hub memberships register <cluster_name> \
--gke-cluster <cluster_location>/<cluster_name> \
--enable-workload-identity \
--project=<project_id>
Verify membership by running the following command:
gcloud container hub memberships list --project=<project_id>
Step 3: Config cluster
For more info on configuring the config cluster, see a Google doc here: Setting up Multi Cluster Ingress | Kubernetes Engine Documentation | Google Cloud.
Enable the US cluster as the config cluster:
gcloud alpha container hub ingress enable --config-membership=clouddns-us
Verify the config cluster:
gcloud alpha container hub ingress describe
Output should look something like:
multiclusteringressFeatureSpec:
configMembership: projects/<project id>/locations/global/memberships/<cluster-membership-name>
Step 4: MCI Preparation
1. Create a Static IP
A static IP is required for the HTTP(S) load balancer. See the Google doc here: https://cloud.google.com/kubernetes-engine/docs/how-to/multi-cluster-ingress-setup#specifying_a_config_cluster
Add the IP address to the MultiClusterIngress file using the static-ip annotation:
annotations:
networking.gke.io/static-ip: <static ip address>
2. SSL cert for the HTTP(S) load balancer There are various options for generating an SSL cert for external traffic to the HTTP(S) load balancer.
- Pre-shared certificates doc: https://cloud.google.com/kubernetes-engine/docs/how-to/multi-cluster-ingress#pre-shared_certificates
- Google managed certificates doc: https://cloud.google.com/kubernetes-engine/docs/how-to/multi-cluster-ingress#google-managed_certificates
- Configure SSL cert as Kubernetes secret doc: https://cloud.google.com/kubernetes-engine/docs/how-to/multi-cluster-ingress#https_support
For the first two options, update the MultiClusterIngress file using the pre-shared-certs annotation:
annotations:
networking.gke.io/pre-shared-certs: "certname"
3. Configure FQDN
Add FQDN to the host property in the MultiClusterIngress file.
rules:
- host: <fqdn>
4. Deploy the custom resources to the config server
cd etc/multi-cluster/google-cloud/multi-cluster-ingress/mci
kubectl apply -f mci.yaml -n prod
kubectl apply -f mcs.yaml -n prod
kubectl apply -f backendconfig.yaml -n prod
For more information on the above resources see the Google doc links below:
- MultiClusterIngress (mci.yaml): https://cloud.google.com/kubernetes-engine/docs/concepts/multi-cluster-ingress#multiclusteringress_resource
- MultiClusterService (mcs.yaml): https://cloud.google.com/kubernetes-engine/docs/concepts/multi-cluster-ingress#multiclusterservice_resources
- BackendConfig (backendconfig.yaml): Deploying Ingress across clusters | Kubernetes Engine Documentation | Google Cloud
Step 5: Deploy Frontend Apps
1. Deploy AM, IDM and the UIs
This example reflects a CDM medium size deployment which is the size used for testing. Please adjust to suit your requirements.
bin/forgeops install apps ui --medium
2. Verify deployment
Things to check:
All pods are deployed
kubectl get pods
You can access the UIs e.g. https://prod.mci.forgeops.com/platform.
Load balancer pod status is green and backend services are green (healthchecks passed) e.g.
https://console.cloud.google.com/kubernetes/multiclusteringress/us-west1-b/clouddns-us/prod/forgerock/details?project=\https://console.cloud.google.com/kubernetes/multiclusteringress/us-west1-b/clouddns-us/prod/forgerock/details?project=\<projectID>
Verify requests from a US and EU location go to their relevant/local clusters.
Step 6: Delete the deployment
Carry out the following commands in each cluster:
bin/forgeops delete apps ui
Step 7: Delete the multi-cluster ingress configuration
1. Remove configs from config cluster
From the config cluster:
kubectl delete mcs --all
kubectl delete backendconfig --all
kubectl delete mci forgerock
2. Remove clusters from fleet
gcloud container hub memberships delete clouddns-eu
gcloud container hub memberships delete clouddns-us
Step 8: Pricing
Step 9: Testing
The following tests have been carried out across two clusters in different regions unless specified (failover is triggered by scaling down product to 0 pods):
- Verify geolocation.
- Test failover between europe-west1 and europe-west2/europe-west2 and us-west-2
- Failover IDM while creating users.
- Test failover of AM across 3 clusters in different regions.
- Test split load by running test against 1 location with low available resources.
- Failover IDM based on idrepo being down.
- Failover AM which running AuthN and Access Token simulations.
- Test failover across 3 different clusters.
- Running performance tests for 1,6 and 12 hour durations.
- Running AM performance tests with stateful and stateless tokens.
- Running load simulataneously across 2 clusters and forcing failover of AM.
TO DO
- Use health check status to manage failovers:
- Fail over IDM if AM is down
- Fail over AM if idrepo or cts is down
- Fail over IDM if idrepo is down
- Enable SSL endpoint of AM
- Resolve throuput ussues after 7 hours durin dual load performance testing
- IG/RCS agent?
