For an app integrated with ID cloud using OIDC, we need to add a custom claim in the ID token.
The value for the claim needs to be fetched from another system using a REST API call.
Lets say: “CBD Number”: 123-45
How can we achieve this?
Hello @ajaykumar_suri,
Thank you for reaching out to our Community site.
For customizing the OIDC claims and retrieving the claim value please refer to the sample scripts page: Sample scripts :: ForgeRock Identity Cloud Docs → oidc-claims-extension.js
Or access the script directly at:
[https://backstage.forgerock.com/docs/idcloud/latest/_attachments/scripts/oidc-claims-extension.js]
You would customer this block:
utils.setClaimResolvers({
// An example of a simple claim resolver function that is defined for a claim
// directly in the configuration object:
custom-claim-name: function (requestedClaim) {
// In this case, initially, the claim value comes straight from a user profile attribute value:
var claimValue = identity.getAttribute('custom-attribute-name').toArray()[0]
// Optionally, provide additional logic for processing (filtering, formatting, etc.) the claim value.
// You can use:
// requestedClaim.getName()
// requestedClaim.getValues()
// requestedClaim.getLocale()
// requestedClaim.isEssential()
return claimValue
* The use of utils.getUserProfileClaimResolver shows how
* an argument passed to a function that returns a claim resolver
* becomes available to the resolver function (via its lexical context).
family_name: utils.getUserProfileClaimResolver('sn'),
given_name: utils.getUserProfileClaimResolver('givenname'),
zoneinfo: utils.getUserProfileClaimResolver('preferredtimezone'),
locale: utils.getUserProfileClaimResolver('preferredlocale'),
email: utils.getUserProfileClaimResolver('mail'),
address: utils.getAddressClaimResolver(
* The passed in user profile claim resolver function
* can be used by the address claim resolver function
* to obtain the claim value to be formatted as per the OIDC specification:
* @see https://openid.net/specs/openid-connect-core-1_0.html#AddressClaim.
utils.getUserProfileClaimResolver('postaladdress')
phone_number: utils.getUserProfileClaimResolver('telephonenumber')
I hope this helps!
Warm Regards,
Ed
Thank you, Ed
