Hello
I am creating some new attributes in IDM to an object and need to be able to query / filter the attribute based on another. Essentially, this is an Organization update, which I need to filter / return only existing orgIDs if they match a certain attribute assigned to those attributes. So, this is a virtual attribute based on filter of orgIDs on the object when they meet certain criteria / calculated. Was going to use an onRetrieve script to filter those but trying to find an example of an onretrieve script to run the filter or other query syntax (e.g. orgattribute = true) for the virtual attribute.
Nick
