I’m trying to set up ForgeRock-AM and use OAuth2 Provider service. I’m passing login_hint on the authorization URL but there seems to have no effect on the login page (username not populated). My authentication modules are on default settings (uses uid for searching users) and I’m passing an existing username as my login_hint.
Is login_hint working in AM 7.2? Appreciate any pointers or setup guide to make login_hints work.
Thank you,
Ryan Solomon
My Forgerock AM version is 7.2
Related guide docs I’ve come across so for are:
/docs/am/7.2/oauth2-guide/oauth2-authorize-endpoint.html
/docs/am/7.2/oidc1-guide/oidc-mobile-connect.html
am 7.0 known issue
