Post logout error from forgerock
I have setup Forgerock as idp with my application I am able to login but after logging out I am getting this error as shown in the following image
I am unable to find the issue behind this error and would like to have some suggestions about it. Thanks in Advance!
Hi @mwtech would you like to suggest something about this issue.
Hi @hakxcore, from the URL in your screenshot, it looks like you are sending a SAMLRequest to a logout endpoint, which can not work as SAMLRequests are used for login to the IDP, not logout.
How are your generating the logout?
A SAMLRequest parameter will be used in a SAML logout initiated by a service provider, which I am suspecting is the “application” you referenced in your original post.
Have you looked at the Federation debug log at all? The debug log files are your best friends when it comes to troubleshooting issues. I’d suggest taking a look at the Federation debug log (at /path/to/am/var/debug) and seeing what error(s) it contains. If that error message isn’t enough information to work with, it can’t hurt to step up the debug level to MESSAGE and running through your test again.
Hi @mwtech and @nathalie.hoet, I have tried to reference this article but no positive resonse.
Here are my Fedration logs:
[CONTINUED]com.sun.identity.saml2.common.SAML2Exception: Single Logout Response Service location not found.
	at com.sun.identity.saml2.profile.IDPSingleLogout.getLogoutResponseEndpoint(IDPSingleLogout.java:572)
	at com.sun.identity.saml2.profile.IDPSingleLogout.processLogoutRequest(IDPSingleLogout.java:517)
	at org.apache.jsp.saml2.jsp.idpSingleLogoutRedirect_jsp._jspService(idpSingleLogoutRedirect_jsp.java:254)
	at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:623)
	at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:466)
	at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:379)
	at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:327)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:209)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:153)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:178)
	at org.forgerock.openam.headers.SecureCookieFilter.doFilter(SecureCookieFilter.java:63)
	at org.forgerock.openam.headers.DisableSameSiteCookiesFilter.doFilter(DisableSameSiteCookiesFilter.java:106)
	at org.forgerock.openam.validation.ResponseValidationFilter.doFilter(ResponseValidationFilter.java:59)
	at org.forgerock.openam.headers.SetHeadersFilter.doFilter(SetHeadersFilter.java:110)
	at com.sun.identity.setup.AMSetupFilter.doFilter(AMSetupFilter.java:116)
	at org.forgerock.openam.validation.RequestEntitySizeVerificationFilter.doFilter(RequestEntitySizeVerificationFilter.java:72)
	at org.forgerock.openam.audit.context.AuditContextFilter.doFilter(AuditContextFilter.java:47)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:167)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:481)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:673)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
	at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:390)
	at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
	at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:926)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1791)
	at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
	at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
	at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.base/java.lang.Thread.run(Thread.java:829)
I also made changes in these URLs with the help of that referenced article.
From that error it looks like you don’t have a single logout service defined in your SP configuration. Your SP initiated a SAML logout request and AM wants to send it a response to that request but it can’t do so as it cannot find a location to send it. Typically this information will come in the metadata of your SP, and you can also configure it via the AM admin UI.
