I created a new internal role to allow users to be able to run searches via the API against themselves along with roles / applications in IDM. When doing a search against the role or applications object, if I do a direct search using the /managed/<role|application>/ I get a return. But, when I run a search against object with a queryFilter parameter, I get an error with 403, unauthorized, no matching privilege found. Is there a specific privilege that is needed to allow an API request to use the queryFilter parameter?
Nick
