The documentation in Policies over REST :: AM 7.3.0 did not give an example how to use the reserved keyword IP in the evaluation script.
Here is an example
curl -s --request POST --header ‘iPlanetDirectoryPro: DUr4Avc9KLImXBYt87C0ZVvNE6c.AAJTSQACMDIAAlNLABx3RUR3Vk5va2hVOUlSV3RBVENJYVdxcHNEN0U9AAR0eXBlAANDVFMAAlMxAAIwMQ…’ --header ‘Accept-API-Version: resource=2.1’ --header ‘Content-Type: application/json’ --data ‘{
“resources”: [ “http://eave.internal.example.com:8000/index.html”
“subject”: {
“ssoToken”: “lQjRVeydW7KwH1ayGm-qFepDk8A.AAJTSQACMDIAAlNLABxKNmw2SXhweGJTTDFiNzZ1RkhiU0ZQbWFnL1E9AAR0eXBlAANDVFMAAlMxAAIwMQ…” },
“application”: “iPlanetAMWebAgentService”,
“environment”: { “IP”: [“[192.168.xxx.50]”, “[192.68.xxx.x]”],
“ipaddress”: []
}’ ‘http://openam.internal.example.com:8080/openam/json/realms/root/policies?_action=evaluate’
Hi @sam.phua, thank you for sharing your invaluable knowledge and providing a working example of how to use the reserved keyword “IP” in the evaluation script. Once again, your proactive insights greatly benefit the entire community, and we deeply appreciate your insights and contributions!
Here is an example
“subject”: {
“ipaddress”: []
