WebAuthN deviceName collector
Anastasios Kampas
Mar 2023
Mar 2023
Use case overview
When authenticating in AM using the WebAuthN out-of-the-box nodes, a new trusted device will be saved in the User’s profile. By default, the device name will be ‘New Security Key’. The same name will be used for every newly registered device. The user can change the device name after the authentication in the user profile > trusted devices section.
Here you can find a way to collect the device name from the user in order to avoid the same name being used.
Prerequisites
  • In the WebAuthnRegistration node, you must enable “Store device data in the transient state”
  • In the Scripted Decision node config, you need to add webauthnDeviceData as script input.
Scripted decision node
The small script in this case just returns a prompt to the user to provide a name for the device he/she is registering for the first time. The user can provide a name or skip and use the default name.
 * Takes the nodeState webauthnDeviceData object, prompts the user for a user-friendly name of the device,
 * updates the transientState. If user skips it, then it does nothing.
 * Node imports
var javaImports = JavaImporter(
    org.forgerock.openam.auth.node.api.Action,
    javax.security.auth.callback.ConfirmationCallback,
    javax.security.auth.callback.NameCallback,
    java.lang.String
 * Node outcomes
var nodeOutcomes = {
    SAVE: "save",
    SKIP: "skip"
 * Node config
var nodeConfig = {
    BUTTONS: ["SAVE", "SKIP"],
    SAVE_ACTION_PRESSED: 0,
    SKIP_ACTION_PRESSED: 1,
    deviceDataSharedStatePropertyName: "webauthnDeviceData",
    callbackDisplayTextDeviceNameInput: "Security key name",
    nodeName: "***SecurityKeyNameCollector"
 * Node logger
var nodeLogger = {
    debug: function(message) {
        logger.message("***" + nodeConfig.nodeName + " " + message);
    warning: function(message) {
        logger.warning("***" + nodeConfig.nodeName + " " + message);
    error: function(message) {
        logger.error("***" + nodeConfig.nodeName + " " + message);
 * Main
(function() {
    nodeLogger.debug("node executing");
    if (callbacks.isEmpty()) {
        action = javaImports.Action.send(
            javaImports.NameCallback(nodeConfig.callbackDisplayTextDeviceNameInput),
            javaImports.ConfirmationCallback(javaImports.ConfirmationCallback.INFORMATION, nodeConfig.BUTTONS, 0)
        ).build();
        var userSelection = callbacks[1].getSelectedIndex();
        nodeLogger.debug("User selected: " + userSelection);
        if (userSelection === nodeConfig.SAVE_ACTION_PRESSED) {
            var deviceInputName = javaImports.String(callbacks.get(0).getName());
            nodeLogger.debug("Setting new device name:" + deviceInputName);
            var webauthnDeviceData = nodeState.get(nodeConfig.deviceDataSharedStatePropertyName);
            webauthnDeviceData.put("deviceName", deviceInputName);
            transientState.put("webauthnDeviceData", webauthnDeviceData);
            action = javaImports.Action.goTo(nodeOutcomes.SAVE).build();
            action = javaImports.Action.goTo(nodeOutcomes.SKIP).build();
Journey overview
The WebAuthN registration tree will look like:
https://backstage-community-prod.storage.googleapis.com/original/2X/8/815c722095c5f17f76784cba1233e6925d2aa8ff
Node prompt
https://backstage-community-prod.storage.googleapis.com/original/2X/8/8f7bf6b7a27563333992640709a72f992c000906
So, whilst the default name is not ideal, this is an easy way to overwrite the device name during authentication if the user chooses it.
