What are the options available for ForgeRock to be integrated with Magento, need any documentation or steps
Hi @htammineni ,
Welcome to the ForgeRock Community!
Just confirming your inquiry is for an SSO integration? If yes, I checked with our internal practitioners, and although we do not have specific steps for Magento, integrations into platforms like this are becoming more commonplace and a few suggestions were offered:
The following reference to https://developer.adobe.com/commerce/webapi/get-started/authentication/#javascript-widget-authentication-storefront-or-admin
seems suitable and would just need an integrator to build out based on which option you choose.
One of internal practitioners completed a similar solution with Shopify.
It was just an exercise of working through the Shopify docs and a working knowledge of AM. The project is provided below for your reference:
- Shopify example: forgerock-scripts/JourneyScripts/Shopify at master · afalahi/forgerock-scripts · GitHub
The classes were added to the Identity cloud whitelist.
- There is also former experience with integrated Magento with FR using OIDC/OAuth2 using a plugin similar to this one (which, as is often the case, has no mention of FR). Simply required OIDC/OAuth2 client configuration in FR to work. https://marketplace.magento.com/miniorange-inc-miniorange-oauth-sso.html
I hope this information helps!
