This is the continuation of the previous blog about a Zero Downtime Upgrade Strategy Using a Blue/Green Deployment for AM. Traditionally, ForgeRock Directory Server (DS) upgrades are handled via a rolling upgrade strategy using an in-place update. As many deployments have constraints around this approach (zero downtime, immutable, etc.), a parallel deployment approach, also known as a blue/green strategy, can be leveraged for upgrading ForgeRock DS servers.
Note: In this article, the blue cluster reflects an existing DS deployment (3.5.x version), and the green reflects a new DS deployment (6.5.x version).
This blog provides a high-level approach for using a blue/green methodology for updating ForgeRock DS-UserStores.
This corresponds to Unit 3: DS-UserStores in our overall ForgeRock upgrade approach.
ForgeRock Upgrade Units
Unit 3: DS-Userstores Upgrade Process
Prerequisites/Assumptions
This approach assumes that your infrastructure processes have the ability to install a parallel deployment for an upgrade, or you are already using a blue/green deployment.
In the above diagram, the blue cluster reflects an existing DS deployment (like a 3.5.x version), and the green reflects a new DS deployment (like a 6.5.x version).
There are N+1 DS servers deployed in your existing deployment. N servers are used for your production workload and one server is reserved for maintenance activities like backup, upgrades, etc. If there is no maintenance server, then you may need to remove one server from the production cluster (thereby reducing production load capacity) or install an additional DS server node for this upgrade strategy.
Review release notes for all DS versions between existing and target DS deployments for new, deprecated features, bug fixes, and others. For a DS 3.5 to DS 6.5 upgrade, review the Release Notes for DS 5.0, 5.5, 6.0, and 6.5 versions.
Upgrade Process
Unconfigure replication for the DS-3 user store. Doing so ensures that the upgrade doesn’t impact your existing DS deployment.
Upgrade DS-3 in place using DS upgrade process.
Create a backup from DS-3 using the DS backup utility.
Configure green RS-1’s replication with the existing blue replication topology.
Configure green RS-2’s replication with the existing blue replication topology.
Install green DS-1 and restore data from backup using the DS restore utility.
Install green DS-2 and restore data from backup using the DS restore utility.
Install Green DS-3 and restore data from backup using the DS restore utility.
Configure Green DS-1’s replication with Green RS-1.
Configure Green DS-2’s replication with Green RS-1.
Configure Green DS-3’s replication with Green RS-1.
Switch Over to the New Deployment
- After validating that the new deployment is working correctly, switch the load balancer from blue to green. This can also be done incrementally. If any issues occur, you can always roll back to the blue deployment.
If direct hostnames are used by DS clients, such as AM, IDM, etc., then those configurations need to be updated to leverage new green hostnames.
Post Go-Live
Unconfigure the blue RS1 replication server to remove this server from blue’s replication topology.
Unconfigure the blue RS2 replication server to remove this server from blue’s replication topology.
Stop the blue DS servers.
Stop the blue RS servers.
De-provision the blue deployment.
Although a blue/green deployment requires a high level of deployment maturity, this approach provides an elegant way to minimizing downtime for ForgeRock deployment upgrades. It is always advisable to try an upgrade strategy in lower environments like dev, stage before moving to a production environment.
Depending on the complexity of your deployment, there can be multiple things to be considered for these upgrades, such as customizations, new FR features, etc. It is always recommended to break the entire upgrade process into multiple releases like “base upgrade” followed by “leveraging new features”, and so on.
