How to Use ESVs for Federation of Admins
Hope Sun |
Nov 2024 |
Nov 2024 |
Select tenant settings → federation, and add new identity provider
If you are using different azure tenant for different env, please also use esv for Well known end point **
If you are using group, please use esv for group id
Please use esv for secret
If you have multiple SSO config, you can edit the button text to assign different text for different SSO options
