Restricting AM REST Administration to Certain IP Addresses Using
Sheila Albertelli
Oct 2020
Oct 2020
There are numerous ways to restrict and protect REST calls by implementing the correct logic in the proxy layer. ForgeRock® Identity Gateway (IG) or an API Gateway can be used to accomplish this type of use case. The approach I will be discussing utilizes basic Apache mod_rewrite rules to only allow ForgeRock® Access Management (AM) REST administration from a specific set of IP addresses.
==== Prerequisites
Enable the module
For reference, my lab environment is running the following:
  • Two load-balanced (mod_proxy) AM servers (6.5.x)
  • Apache 2.4.6/CentOS 7
To enable mod_rewrite, navigate to the base configuration file and uncomment the mod_rewrite line if needed.
vi /etc/httpd/conf.modules.d/00-base.conf
LoadModule rewrite_module modules/mod_rewrite.so
Configure rewrite rules
A .htaccess file can be created to modify rewrite rules without using the httpd configuration file. Make sure Apache allows the use of this file:
<Directory “/var/www”>
 AllowOverride All
 # Allow open access:
 Require all granted
</Directory>
The rewrite rules for this exercise are defined as:
<Location /openam652/>
RewriteEngine On
RewriteCond %{HTTP:X-OpenAM-Username} amadmin [NC]
RewriteCond %{REMOTE_ADDR} !^192\.168\.1\.7
RewriteRule . - [R=403,L]
</Location>
As part of the above rule/condition, I have included the header X-OpenAM-Username that will block any request containing ‘amadmin’ with a 403 except from IP 192.168.1.7.
Note: You can use the LocationMatch directive for regex matching and to enable case-insensitive mode = (?i).
Result
From IP 192.168.1.10:
curl -X POST -H "X-OpenAM-Username: tuser1" -H "X-OpenAM-Password: Password1" -H "json" -H "Accept-API-Version: resource=2.1" -k http://lb.example.com/openam652/json/realms/root/authenticate
{"tokenId":"Yktxsc3LaDgVhFEuQ1BHxSQV-7s.*AAJTSQACMDIAAlNLABw5aXlMUkxTNDZOOFVPaHNyS1JWTE9nV091Y0U9AAR0eXBlAANDVFMAAlMxAAIwMQ..*","successUrl":"/openam652/console","realm":"/"}
curl -X POST -H "X-OpenAM-Username: amadmin" -H "X-OpenAM-Password: cangetinam" -H "json" -H "Accept-API-Version: resource=2.1" -k http://lb.example.com/openam652/json/realms/root/authenticate
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>403 Forbidden</title>
</head><body>
<h1>Forbidden</h1>
<p>You don't have permission to access /openam652/json/realms/root/authenticate
on this server.</p>
</body></html>
From IP 192.168.1.7:
curl -X POST -H "X-OpenAM-Username: amadmin" -H "X-OpenAM-Password: cangetinam" -H "Content-Type: application/json" -H "Accept-API-Version: resource=2.1" -k http://lb.example.com/openam652/json/realms/root/authenticate
{"tokenId":"XNPn56PB-wOQ_yoqgPmHTvejl9c.*AAJTSQACMDIAAlNLABxTMVFRSjl4dkR3YzdmWXpLWUg2VlozcTVia2s9AAR0eXBlAANDVFMAAlMxAAIwMQ..*","successUrl":"/openam652/console","realm":"/"}
The Apache mod_rewrite module is a powerful tool. This example can be used as a stepping stone to develop more advanced specific rules depending on the requirement/use case you may have. The key here is to allowlist/denylist appropriately.
For more information on how to control access using this module, visit https://httpd.apache.org/docs/trunk/rewrite/access.html.
Recommended Reads:
Eight Ways to Blacklist with Apache’s mod_rewrite | Perishable Press
Presenting eight of the most commonly employed blacklisting and rewriting methods achieved with Apache’s incredible rewrite module, mod_rewrite..
Invite Only: Traffic Control via Whitelist | Perishable Press
Web developers trying to control comment-spam, bandwidth-theft, and content-scraping must choose between two fundamentally different approaches:…​
