Configuring ForgeRock AM Active/Active Deployment Routing Using IG
Charan Mann
Nov 2019
Jun 2022
The standard deployment pattern for ForgeRock Identity Platform is to deploy the entire platform in multiple data centers/cloud regions. This is ensures the availability of services in case of an outage in one data center. This approach also provides performance benefits, as the load can be distributed among multiple data centers. Below is the example diagram for Active/Active deployment:
https://backstage-community-prod.storage.googleapis.com/original/1X/60c9d8771634d9a088e3d957bbf9e206e40408e7
Problem Statement
AM provides both stateful/CTS-based and stateless/client-based sessions. Global deployment use cases require a seamless, single sign-on (SSO) experience among all applications with following constraints:
  • Certain deployments have distributed applications, such as App-A, deployed only in Data Center-A, and App-B, deployed only in Data Center-B.
  • The end user may travel to different locations, such as from the East coast to the West coast in the U.S. This means that application access requests will be handled by different data centers.
To achieve these use cases, CTS replication has to be enabled across multiple data centers/cloud regions.
In some situations, a user may try to access an application hosted in a specific data center before their corresponding sessions have been replicated. This can result in the user being prompted to re-authenticate, thereby degrading the user experience:
https://backstage-community-prod.storage.googleapis.com/original/1X/5767f01ae939b7996e8059fbc9905045f19b5f71
Note: This problem may be avoided if client-based sessions are leveraged, but many deployments have to use CTS-based sessions due to current limitations in client-based sessions. Also, when CTS-based sessions are used, the impact of CTS replication is much more than in client-based sessions.
In this article, we leverage IG to intelligently route session validation requests to a single data center, irrespective of the application being accessed.
Solution
IG can route session validation requests to a specific data center/region, depending on an additional site cookie generated during user’s authentication.
This approach ensures that the AM data center that issued the user’s session is used for corresponding session validation calls. This also means that CTS replication is not required across multiple data centers/ cloud regions:
https://backstage-community-prod.storage.googleapis.com/original/1X/0a60be25464c4865918cb2964694d5bc5ac3bee6
Configure AM
  • Install AM 6.5.x and corresponding DS stores, Amster, and others. Following is a sample Amster install command:
install-openam — serverUrl http://am-A.example.com:8094/am — adminPwd cangetinam — acceptLicense — userStoreDirMgr “cn=Directory Manager” — userStoreDirMgrPwd “cangetindj” — userStoreHost uds1.example.com — userStoreType LDAPv3ForOpenDS — userStorePort 1389 — userStoreRootSuffix dc=example,dc=com — cfgStoreAdminPort 18092 — cfgStorePort 28092 — cfgStoreJmxPort 38092 — cfgStoreSsl SIMPLE — cfgStoreHost am-A.example.com — cfgDir /home/forgerock/am11 — cookieDomain example.com
am> connect http://am-A.example.com:8094/am -i
Sign in
User Name: amadmin
Password: **********
amster am-A.example.com:8094> import-config — path /home/forgerock/work/amster
Importing directory /home/forgerock/work/amster
Imported /home/forgerock/work/amster/global/Realms/root-employees.json
Imported /home/forgerock/work/amster/realms/root-employees/CoookieSetterNode/e4c11a8e-6c3b-455d-a875–4a1c29547716.json
Imported /home/forgerock/work/amster/realms/root-employees/DataStoreDecision/6bc90a3d-d54d-4857-a226-fb99df08ff8c.json
Imported /home/forgerock/work/amster/realms/root-employees/PasswordCollector/013d8761–2267–43cf-9e5e-01a794bd6d8d.json
Imported /home/forgerock/work/amster/realms/root-employees/UsernameCollector/31ce613e-a630–4c64–84ee-20662fb4e15e.json
Imported /home/forgerock/work/amster/realms/root-employees/PageNode/55f2d83b-724b-4e3a-87cc-247570c7020e.json
Imported /home/forgerock/work/amster/realms/root-employees/AuthTree/LDAPTree.json
Imported /home/forgerock/work/amster/realms/root/J2eeAgents/IG.json
Import completed successfully
- Creates /root realm aliases: am-A.example.com and am-B.example.com- AM Agent to be used by IG in /root realm- LDAPTree to create cookie after authentication. Update Cookie value as DC-A or DC-B, dependending on datacenter being used
  • Repeat the previous steps for configuring AM in all data centers:
https://backstage-community-prod.storage.googleapis.com/original/1X/c3feca6126ab53c473b7803fff87041cd4b6f96d
Configure IG
- frProps.json to specify AM primary and secondary DC endpoints. Refer frProps-DC-A for DC-A and frProps-DC-B for DC-B.- config.json to declare primary and secondary AmService objects- 01-pep-dc-igApp.json to route session validation to specific datacenter, depending on “DataCenterCookie” value.
  • Repeat the previous steps for deploying IG in all data centers.
Test the use cases
The user accesses an application deployed in DC-A first
  1. The user accesses app1.example.com, deployed in DC-A.
  2. IG, deployed in DC-A, redirects the request to AM, deployed in DC-A for authentication.
  3. A DataCenterCookie is issued with a DC-A value.
  4. The user accesses app2.example.com, deployed in DC-B.
  5. IG, deployed in DC-B, redirects the request to AM, deployed in DC-A, for session validation.
The user accesses an application deployed in DC-B first
  1. The user accesses app2.example.com deployed in DC-B.
  2. IG, deployed in DC-B, redirects the request to AM deployed in DC-B, for authentication.
  3. A DataCenterCookie is issued with a DC-B value.
  4. The user accesses app1.example.com, deployed in DC-A.
  5. IG, deployed in DC-A, redirects request to AM, deployed in DC-B, for session validation.
Extend AM to OAuth/OIDC use cases
OAuth: AM 6.5.2 provides option to modify Access tokens using scripts. This allows additional metadata in stateless OAuth tokens, such as dataCenter. This information can be leveraged by IG OAuth RS to invoke the appropriate data center’s AmService objects for tokenInfo/ introspection endpoints:
 “sub”: “user.88”,
 “cts”: “OAUTH2_STATELESS_GRANT”,
 “auth_level”: 0,
 “iss”: “http://am6521.example.com:8092/am/oauth2/employees",
 “dataCenter”: “DC-A”
OIDC: AM allows additional claims in OIDC tokens using scripts. This information can be leveraged by IG to invoke appropriate dataceter’s AmService objects
The standard deployment for the ForgeRock Identity Platform consists of multiple ForgeRock products such as IG, AM, IDM, and DS. As newer ForgeRock versions are released, deployments using older versions need to be migrated before they reach their end of life. Also, newer versions of ForgeRock products provide features such as intelligent authentication and the latest OAuth standards, which help businesses implement complex use cases. [FR-Deployment-Components-Charan-1024x798] ForgeRock …
Introduction This is the continuation of the previous blog about a Zero Downtime Upgrade Strategy Using a Blue/Green Deployment for AM. Traditionally, ForgeRock Directory Server (DS) upgrades are handled via a rolling upgrade strategy using an in-place update. As many deployments have constraints around this approach (zero downtime, immutable, etc.), a parallel deployment approach, also known as a blue/green strategy, can be leveraged for upgrading ForgeRock DS servers. Note: In this article, t…
