Multi-Cluster Deployment for DS on GKE Using Cloud DNS for GKE
Lee Baines
Jan 2022
May 2022
Cloud DNS for GKE is currently in Preview.
Google documentation here.
This article explains how to deploy DS across two different GKE clusters, using one cluster in the US and one cluster in Europe. For different cluster names, just replace eu and us in the various files mentioned in the setup steps below.
There are 5 major steps to the deployment:
  • Prepare two clusters configured to use Cloud DNS with one in the US and one in Europe.
  • Enable the use of shared secrets across the clusters.
  • Create firewall rules to allow replication traffic between clusters.
  • Prepare Kustomize configuration to ensure unique server IDs and configure bootstrap servers.
  • Deploy DS using the provided Skaffold profiles.
Step 1: Prepare clusters
Provision two clusters with following requirements:
  • Same VPC
  • In different regions, if multi-region (below example is configured in eu and us).
  • Create the same namespace in each cluster for DS (default: prod).
  • Workload Identity-enabled (for Secret Agent).
  • Configure your Cloud DNS domain name (see below).
Create your cluster as described in the forgeops docs, but also include the following arguments where cluster domain will be the domain configured for that cluster e.g. the following will replace pod domain .cluster.local with .us for the us cluster:
  • Same VPC
--cluster-dns clouddns \
--cluster-dns-scope vpc \
--cluster-dns-domain us
There is a helpful script to create your cluster cluster-up.sh.
Edit the multi-cluster.sh file with your cluster spec including required values for:
  • CLOUD_DNS_DOMAIN
  • REGION
Then run the following commands:
source cluster/gke/multi-cluster.sh
cluster/gke/cluster-up.sh
Step 2: Configure firewall rules
Firewall rules need to be created to allow replication traffic between clusters. Either manually create firewall rules or there is a sample bash script that will create these for you:
/etc/multi-cluster/clouddns/create-firewall-rules.sh
Just edit the cluster names at the top of the script.
# Specify your cluster names
CLUSTER1="clouddns-eu"
CLUSTER2="clouddns-us"
Firewall rules will be generated with these cluster names.
Step 3: Enable the use of shared secrets across the clusters
Deploy secret-agent in each cluster:
bin/secret-agent.sh
Follow the instructions to configure secret-agent to work with Workload Identity: Instructions.
Step 4: Prepare Deployment
1. Configure secret-agent parameters
NOTE: Please check values and update to match requirements
In `kustomize/overlay/multi-cluster/multi-cluster-secrets/kustomization.yaml,`fill out the following fields:
  1. secretsManagerPrefix: # ensures unique secret names in Secret Manager.
  2. secretsManager: GCP
  3. gcpProjectID:
2. Configure clusters
NOTE: Currently these files are configured based on eu and us regions. These values must match the value provided for --cluster-dns-domain names registered in step 1.
Change the DS_CLUSTER_TOPOLOGY env var for a different list of regional identifiers.
See ds-idrepo.yaml and ds-cts.yaml in kustomize/overlay/multi-cluster/clouddns.
env:
- name: DS_CLUSTER_TOPOLOGY
  value: "eu,us"
The above change needs to be applied to the idrepo and cts patch in the ds-cts.yaml and ds-idrepo.yaml files.
Step 4: Deploy
Deploy following profile to both clusters:
skaffold run --profile clouddns
Step 5: Verify replication
The best way to check replication is using Grafana. This can be deployed as part of the Prometheus Operator Helm chart package using our sample script:
bin/prometheus-deploy.sh
Connect to Grafana:
kubectl port-forward $(kubectl get pods --selector="app.kubernetes.io/name=grafana" --field-selector status.phase=Running --output=jsonpath="{.items..metadata.name}" --namespace=$NAMESPACE) $PORT:3000 --namespace=$NAMESPACE
Then type localhost:3000 in your browser to view Grafana.
Go to the ForgeRock Directory Services dashboard and look at the receive delay graph to confirm that ds pods in each cluster are receiving traffic from each other.
If traffic isn’t replicating between clusters, then revisit the steps in this article, and check the Google Cloud documentation described here.
Step 6: Delete
In each cluster, run:
skaffold delete --profile clouddns # Only run the following command if you want to delete all data kubectl delete pvc --all # To retain the idrepo pvcs if you want to hold on to the users kubectl delete pvc data-ds-cts-0 data-ds-cts-1 data-ds-cts-2
Cleanup:
This article shows you how to deploy a multi-region ForgeRock Directory Services (DS) solution that spans two Google Kubernetes Engine (GKE) clusters from different regions using a multi-cluster solution (MCS). This solution lets pods in one GKE cluster to discover pods in another GKE cluster, which simplifies configuration by automating creation of external DNS and firewall rules. Note: We will use the standard stateful applications (DS-CTS and DS-IDREPO) to deploy in each of the two GKE clust…
Google docs: Multi-Cluster Ingress Set Up Multi-Cluster Ingress Deploy Multi-Cluster Ingress Overview This article explains how to deploy the ForgeRock Identity Platform across two different clusters, and configure proximity-based routing with multi-cluster ingress. Features: Fully meshed multi-cluster DS tolopology using CloudDNS for GKE Global HTTP(S) load balancing across multiple clusters with Multi Cluster Ingress Health checks to manage application level failover between clusters Pr…
